Portable Hydraulic Test Stand
68 replies to this topic
#46 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 15, 2017 - 12:23 PM
Wow! Free stuff! I like that!  :dancingbanana:
The engine in the test stand is an 8 HP.  But, I'll take anything for up to 20 HP.   :smilewink:  :worshippy1:  :thumbs:
  • ducky said thank you
#47 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted January 15, 2017 - 01:19 PM
I'll pic one out for you this afternoon.
#48 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted January 15, 2017 - 10:56 PM
Hi Kenny
You can have either or both.
Pump 1 is a 7-10 GPM at about 2000 RPMs
Pump 2 is 10 -12 GPM at around 2500 RPMs
#49 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 16, 2017 - 06:13 AM
Decisions, decisions! Heck with it, send both. I'll help on shipping if need be.
On the first one, are those bolt holes for inlet/outlet ports?
#50 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 16, 2017 - 04:08 PM
I got to go out for a while and mess with this. Finished making the valve actuator (handle).
Here's the first thing to put on there to test. It's the cylinder that will go on the Cub.
Now for a muffler. I am debating on using this one. Just not real happy with the outlet direction. Stuck it on 2 different ways. I know I'll have to support it somehow. The first two pics has it back where I have to stand to start it.
Don't really want to use the 'pepper shaker' things, but may have to.
  • olcowhand, TomLGT195 and 29 Chev have said thanks
#51 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted January 16, 2017 - 05:04 PM
That on takes a flange fittings and the threaded holes are for the fitting
#52 TomLGT195 OFFLINE
TomLGT195
  • 3,468 Thanks
  • 2,660 posts
Posted January 17, 2017 - 04:26 PM
"Don't really want to use the 'pepper shaker' things, but may have to."
 I see a custom exhaust coming.  :dancingbanana:  :dancingbanana:    :smilewink:  :smilewink:
#53 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 17, 2017 - 05:42 PM
Maybe!
#54 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 18, 2017 - 12:10 PM
Who needs a 'custom' exhaust? I just use what's laying about.  :thumbs:
This came with the Magnum 16 I bought a while back! Ought to keep this little K181 quiet!
  • TomLGT195 and Mark 149 J. have said thanks
#55 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 18, 2017 - 02:36 PM
It WORKS!  :dancingbanana:
Had to make a throttle control. That was simple.
Filled it with fluid.
Hooked up the cylinder for the Cub! Found out it has a 4.75" stroke!
And that was at idle. It's very quiet. LOL Guess the exhaust has plenty of room in there to flit around. I'll see about a video in a bit.
  • Alc and 29 Chev have said thanks
#56 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 18, 2017 - 03:09 PM
Here's a short video! I was right next to the muffler outlet.
  • Alc, EricR, TomLGT195 and 2 others have said thanks
#57 TomLGT195 OFFLINE
TomLGT195
  • 3,468 Thanks
  • 2,660 posts
Posted January 18, 2017 - 04:13 PM
Looking good !
#58 KennyP OFFLINE
  • 35,097 Thanks
  • 44,116 posts
Posted January 18, 2017 - 05:33 PM
I dug out the 2 Char-Lynn motors. That is the main reason for this. I had to see if they work. They are a 1" shaft with key. Monsters! Had to break out a 4' cheater to take the lines off them. Then had to go get some NPT reducers as they had 1/2"  and 3/8" NPT fittings. Got the one hooked up and it's good to go! Not real fast. Would make good crawler motors! Anyway here's some pics.
I think the valve hooked between was to control speed. One way was closed. Other is open.
  • olcowhand and Mark 149 J. have said thanks
#59 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted January 18, 2017 - 10:29 PM
This might be of help.
http://harrisburg.cr...5926815306.html
#60 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted January 19, 2017 - 01:00 AM
Kenny
Got those pumps out today Fed Ex.  I'll PM you a tracking # tomorrow.
