Portable Hydraulic Test Stand
63 replies to this topic
#31 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 11, 2017 - 05:35 PM
Well, I can't put a filter on it. First I don't have fittings to hook it in. Second this is not like a hydro with an open center spool. If I did hook a fliter in, when I changed directions with the valve, all that trash would just go back the other way. I'll just purge whatever I hook to it.
We have a fuel tank! Got the mount made up and hooked the line to the carb.
The large zip ties I found in the road, a whole package of them.
I found a bit more room in my slots to move the pump back more. That should help as I know that belt will stretch some.
I the last pic you can see a chalk mark across. That is where the mount was at.
  • olcowhand, sacsr, 29 Chev and 1 other said thanks
#32 29 Chev ONLINE
29 Chev
  • 3,719 Thanks
  • 1,389 posts
Posted January 11, 2017 - 07:52 PM
Looks good.  Is that the only oil drain on the engine or is there another plug on the other side?  The reason I ask is if that is the drain you may want to cut a hole where the plug is to make draining the oil less messy - just a suggestion.
#33 ducky OFFLINE
  • 1,826 Thanks
  • 3,995 posts
Posted January 12, 2017 - 03:52 AM
Kenny that filter should be in the return line between the control valve and the tank.  I think there would be a screen filter on the pick up tube to protect the pump.
#34 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 12, 2017 - 06:02 AM
The valve is built into the pump, Don. And there is no screen. Here's a pic of the innards. The spring is for the valve return to neutral.
  • olcowhand and ducky have said thanks
#35 ducky OFFLINE
  • 1,826 Thanks
  • 3,995 posts
Posted January 12, 2017 - 01:18 PM
Kenny does that pump have two output for dual acting cylinders or to reverse a motor.
#36 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 12, 2017 - 01:31 PM
Not sure what you mean? Depending on which way you move the handle, one side sends fluid out and the other returns it to the pump. Just like an in line valve.
  • ducky said thank you
#37 ducky OFFLINE
  • 1,826 Thanks
  • 3,995 posts
Posted January 12, 2017 - 01:49 PM
That would be a two way valve.  One outlet on the pump.  Fluid is sent out under pressure in one direction and allowed to return back to tank in the other direction though the same port if pressure is applied to the cylinder rod to push it back.
Do I have that right?
For a test unit it may be handy to add a four way valve, one that would have a Pump, Tank, and the A and B port so you could operate the test item in both directions.  It would take adding a fitting to the tank for the return line.  Then the filter could be put in that line to keep dirt out of the pump.
  • olcowhand and KennyP have said thanks
#38 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 14, 2017 - 02:58 PM
I won't mod the pump, Don. I plan to install it on my Cub come spring. it's on here to make sure it works. When I take it off, I plan to put a Chevy power steering pump in it's place. With it, I can install a valve and a filter.
  • ducky and 29 Chev have said thanks
#39 29 Chev ONLINE
29 Chev
  • 3,719 Thanks
  • 1,389 posts
Posted January 14, 2017 - 03:20 PM
Are you planning on using an older Chev power steering pump with the reservoir as part of the pump or the newer style that uses a remote reservoir?
#40 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 14, 2017 - 03:28 PM
Older.
#41 29 Chev ONLINE
29 Chev
  • 3,719 Thanks
  • 1,389 posts
Posted January 14, 2017 - 03:34 PM
If you get a newer on off of a Chevy Van or S truck you could use a separate reservoir (which could contain more oil for larger cylinders) and the pump will have an in and out port - just a suggestion.  Other wise as you probably know you will have to weld or solder in a return port into the pump housing.  Depending on whether you already have the pump and what auto wreckers charge for a used one will be a deciding factor as well.
#42 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 14, 2017 - 04:08 PM
I already have the pump. It's off a 4.3 marine engine. If I had a small tank, I could put it in the return line and get a bit more fluid to work with. But, alas, nothing here as yet.
  • 29 Chev said thank you
#43 secondtry OFFLINE
secondtry
  • 444 Thanks
  • 408 posts
Posted January 14, 2017 - 10:40 PM
For setting up a test unit for things that you can not determine the cleanliness or contamination a large tank with a baffle  system to encourage the settling of contaminants would make a lot of sense.Don
#44 KennyP ONLINE
  • 29,473 Thanks
  • 40,445 posts
Posted January 15, 2017 - 04:56 AM
That would be an issue with this pump, but might be easy to do with the next one. It could have a filter too.
#45 ducky OFFLINE
  • 1,826 Thanks
  • 3,995 posts
Posted January 15, 2017 - 11:40 AM
Kenny
I was digging and cleaning in my shop the other day and I have a lot of take off pumps and valves.  If you would like one I could send it your way.  Best of all FREE.
Like me know what kind horsepower you will use so I do not send something to large.
