Portable Hydraulic Test Stand
68 replies to this topic
#16 skyrydr2 OFFLINE
  • 3,697 Thanks
  • 3,318 posts
Posted January 05, 2017 - 10:18 AM
That explains it!
#17 ducky OFFLINE
  • 1,935 Thanks
  • 4,063 posts
Posted January 05, 2017 - 06:26 PM
Kenny if you are not sure of cleanliness be sure to put a 10 micro filter in the return line.
#18 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 06, 2017 - 05:30 AM
I am a bit concerned about that. I happen to have another filter adapter, but the threads in it are iffy.
I got the return spring yesterday. Too cold to put it in and the seals are not here yet.
  • olcowhand said thank you
#19 Alc ONLINE
  • 5,996 Thanks
  • 6,921 posts
Posted January 06, 2017 - 06:45 AM
Kenny if you could find a flow meter as cheap as I did and a gauge it would complete you test stand and also be handy for other troubleshooting hydraulic
http://gardentractor...ket-flow-meter/
#20 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 06, 2017 - 07:05 AM
Your link in that thread is broken, AL. One of those would be nice, though.
#21 skyrydr2 OFFLINE
  • 3,697 Thanks
  • 3,318 posts
Posted January 06, 2017 - 07:13 AM
Kenny that cylinder is only good for maybe 1000psi. I have it done and awaiting its second leak test.. had to re visit the stuffing box as it leaked around the rod and barrel after it was assembled the first time..DOH!
The stuffing box was thusly redesigned, machined, threaded, and a new steel seal nut machined up to fix the mickey mouse seal abortion it had...
The barrel is thin and could distort under extreme preasure and leak so be for warned.. dont ask too much of it.. lift for a plow would be fine..angling the plow... not so fine..you dont want it pulling. Its not designed for it.
#22 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 06, 2017 - 07:43 AM
Thanks, Keith! Good info to know. Not sure what I will do with it just yet.
#23 Alc ONLINE
  • 5,996 Thanks
  • 6,921 posts
Posted January 06, 2017 - 08:42 AM
Here's what the flowmeter  was like that I got , big $$ if bought new
https://www.instruma...etroleum-fluids
#24 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 06, 2017 - 08:45 AM
Ouch! They are proud of those!
#25 skyrydr2 OFFLINE
  • 3,697 Thanks
  • 3,318 posts
Posted January 07, 2017 - 06:57 AM
Tested cylinder yesterday and all is good now. I'll send it out next week.
  • olcowhand and KennyP have said thanks
#26 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 07, 2017 - 07:27 AM
Sounds good!
#27 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 07, 2017 - 06:22 PM
I got the seals today. Hope to get the pump back together tomorrow and do some parts mounting for the stand.
  • ducky and 29 Chev have said thanks
#28 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 09, 2017 - 04:35 PM
Worked on the stand today! Got the spring and seals in the pump. That spring is fun getting bolted back in there!
Got the wagon wheels mounted and set things back up for a look/see.
Figured out the best spot for the engine and marked the holes for mounting it.
Welded the handles on and bolted the engine down.
Next is making the pump mount. It has to pivot to put the belt on, yet be able to snug the belt for operation. Many options here.
  • olcowhand, ducky, EricR and 2 others have said thanks
#29 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 10, 2017 - 09:41 AM
Been thinking over night and have a plan in my head for the pump mount. Be easier to build it and take pics. Should be a simple affair. Lots to do yet. Need a valve actuator. filter, gas tank & some legs in the front to hold that up.
When I take this pump off to put on the Cub 108, I have a Chevy power steering pump I will replace it with. So the stand won't be just a 'now' thing.
#30 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 10, 2017 - 05:19 PM
Got some more done today! It was beautiful out! The band saw got a work out! Cut a bunch of pieces for the pump mount.
Welded those together where needed. Had to drill some holes for the pivot parts,
Made some slots in the mount angle. May have to revisit those and add a bit more slot. Had to cut a chunk out of my frame as there wasn't a flat spot to bolt this down to. It's welded real good on the bottom side.
Welded the pivot parts to the pump base and aligned the pulleys.
Got some legs on the front for it to sit on.
Got the tensioner made up and installed. Now its time for the filter base mount and the other things I listed above,
  • olcowhand, Alc, TomLGT195 and 1 other said thanks
