Lubricate clutch on Briggs Vanguard electric starter?
8 replies to this topic
#1 MiCarl ONLINE
MiCarl
  • 1,659 Thanks
  • 887 posts
Posted January 04, 2017 - 07:46 AM
My Speedex has a 16HP Vanguard twin with electric start only.
I was having trouble with the starter clutch only engaging about 80% of the time.  I'd have to try several times to get it to grab.  A year ago I replaced the clutch assembly.  It was fine until it got cold, now sometimes it won't engage.
I'm going to be tearing into the tractor today for maintenance.  I'm tempted to apply silicone lubricant to the mechanism to help it throw out.
Any thoughts on whether that would be a good/bad idea?
#2 MH81 ONLINE
  • 29,936 Thanks
  • 29,753 posts
Posted January 04, 2017 - 07:49 AM
Are you talking the Bendix?
Very lite oil and pretty thin stuff.
Silicone would be good for a while, but make sure you clean off the thicker stuff that is slowing the mechanism down.
My experience with silicone is that it 'disappears' or something
Be lubed up and fine, then suddenly the squeak is back and no lubricant.
#3 Cvans OFFLINE
  • 5,784 Thanks
  • 5,741 posts
Posted January 04, 2017 - 08:15 AM
Things may have changed since I was told this. No lubricants on the bendix or shaft. The reason being that it attracts dirt and gets stiff in the cold. I tried graphite thinking it was a dry lubricant but that didn't work either. Keep it spotless and it should work. Having a rear main seal that leaks will also cause starter problems.
  • MH81, Alc, boyscout862 and 1 other said thanks
#4 WHdbJD ONLINE
WHdbJD
  • 654 Thanks
  • 496 posts
Try dry powdered graphite lubricant.  Slick , but does not collect dust/dirt.
#5 boyscout862 ONLINE
  • 11,475 Thanks
  • 8,479 posts
Posted January 04, 2017 - 08:38 AM
Clean the Bendix but no lube, it will attract dirt. Clean all electrical connections, especially battery terminals, solenoid terminals, starter terminal and ground. Make sure battery is fully charged. It is time of the year when batteries die from cold. It has happened to me several times where the starter bendix failure was an indecation that the starter or battery was about to die. The starter wasn't able to spin fast enough to make the bendix engage. Good Luck, Rick
  • MH81 and Cvans have said thanks
#6 MH81 ONLINE
  • 29,936 Thanks
  • 29,753 posts
Posted January 04, 2017 - 08:58 AM
The no lube would make it wear a little faster, but solve both problems.
I learned something today... or relearned something I've forgotten :D
  • Cvans said thank you
#7 MiCarl ONLINE
MiCarl
  • 1,659 Thanks
  • 887 posts
Posted January 04, 2017 - 09:00 AM
I'd read that about the battery/electrical.  The starter seems to spin up quickly but who knows.......
#8 glgrumpy OFFLINE
  • 8,155 Thanks
  • 7,587 posts
Posted January 04, 2017 - 09:13 AM
My Speedex always binds at the compression cycle, even in warm. Goes OK in summer, not so god now. It kinda "Lumps" over and only can do a few times. If no start right away, needs battery boost. All good and bigger wires on system. Is that weak motor then?
#9 MH81 ONLINE
  • 29,936 Thanks
  • 29,753 posts
Posted January 04, 2017 - 10:07 AM
Where are you connecting the booster? If you were can I think its the battery and it makes a difference, your battery is weak.
