Kubota diesel questions
48 replies to this topic
#46 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted May 01, 2017 - 04:59 PM
Polaris these are from kubota d1105T and Diatsu D950T...TD03 and RHF3
#47 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted May 01, 2017 - 05:15 PM
Yoeman putting a turbo on a float type carb requires a air tight box that encases the complete carb otherwise you blow the fuel out of the bowl. Also not sure a single cylinder moves enough exhaust to spin a turbo...
How do you think it would hold up, if it did move enough exhaust, and we encased the carb?
#48 polarisdiesel OFFLINE
polarisdiesel
  • 7 Thanks
  • 31 posts
Posted May 02, 2017 - 06:50 AM
How much do you want for the rhf3? Is it in good working shape
#49 webn237 ONLINE
webn237
  • 20 Thanks
  • 24 posts
Posted July 24, 2017 - 11:26 PM
The stock Kubota turbos add about 5 psi boost and running up to 10 will cause no issues. That being said the more air you push the more fuel you need... the added air in effect leans things out and heats things up. Crank the fuel screw out all the way and it might be enough. Something to keep in mind is for the turbo to be useful you will need to run the engine at full throttle most of the time (3000 -3500). Running a turbo setup at lower rpm will actually decrease the performance over a stock non turbo setup.I have some suitable turbos if you go that way.
Do you still have the small turbo for a kubota d600? If so how much do you want for one?
Sent from my SM-G935R4 using Tapatalk
