Kubota diesel questions
48 replies to this topic
#31 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted January 08, 2017 - 05:30 PM
I'll have a volt meter so it can go to that. It's going to have all the gauges and everything it's going to be really cool lol
Gauges will be up above the radio counsel
Sent from my SM-G935R4 using Tapatalk
#32 miller_time OFFLINE
miller_time
  • 31 Thanks
  • 46 posts
Club car makes a tapered clutch apapter that bolts to the kubota flywheel if you are using a tapered clutch. Its part #102465901 and $66 #14
Sent from my SM-G930V using Tapatalk
#33 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted January 08, 2017 - 05:31 PM
The flywheel had a clutch adapter on it already I'm hoping to reuse with a 780 comet clutch 9035ce37df9e083a7236f2c1ae203b93.jpg08b08f733f0c48aac09b6a5a8b508254.jpg
  • olcowhand and Mark 149 J. have said thanks
#34 miller_time OFFLINE
miller_time
  • 31 Thanks
  • 46 posts
Posted January 08, 2017 - 05:55 PM
Yup that should work perfect for a 780 comet
  • webn237 said thank you
#35 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted January 13, 2017 - 07:26 PM
So I just got my comet clutch and the clutch adapter only goes half way. I don't think that is going to work is it?
#36 miller_time OFFLINE
miller_time
  • 31 Thanks
  • 46 posts
Posted January 13, 2017 - 09:06 PM
Yes it should still be fine. The shaft usually doesn't go in the entire way. I
#37 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted January 13, 2017 - 09:20 PM
Even if it's only half way? Just put a longer bolt in to keep it from pulling off?
#38 miller_time OFFLINE
miller_time
  • 31 Thanks
  • 46 posts
Posted January 14, 2017 - 01:16 PM
Yup longer bolt is all. I have used the 780 in a couple 6x6 amphibious atvs with the briggs vanguard engines. There pto is just under 3" long so a little shorter than yours even.works just fine. They come from the factory that way.
#39 polarisdiesel OFFLINE
polarisdiesel
  • 7 Thanks
  • 31 posts
Posted April 19, 2017 - 02:26 PM
I'd suggest a gt06 for the turbo, or a gt12 but that's probably gonna be a little on the big side for a 600cc. I have a gt12 on a 900cc yanmar and it's a little laggy but it also smokes more when I take off so I like it. And I don't think 8-10 psi will shorten the life of your engine by a noticeable amount. It's a kubota their tough !! And you will be looking at about 25-30% horsepower increase. I vote turbo
#40 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted April 30, 2017 - 10:27 AM
The stock Kubota turbos add about 5 psi boost and running up to 10 will cause no issues. That being said the more air you push the more fuel you need... the added air in effect leans things out and heats things up. Crank the fuel screw out all the way and it might be enough. Something to keep in mind is for the turbo to be useful you will need to run the engine at full throttle most of the time (3000 -3500). Running a turbo setup at lower rpm will actually decrease the performance over a stock non turbo setup.I have some suitable turbos if you go that way.
Edited by DaveBb, April 30, 2017 - 10:33 AM.
  • olcowhand, 637Yeoman and webn237 have said thanks
#41 polarisdiesel OFFLINE
polarisdiesel
  • 7 Thanks
  • 31 posts
Posted April 30, 2017 - 06:11 PM
What size turbos are those ? Any of them ball bearing
#42 637Yeoman ONLINE
637Yeoman
  • 1,570 Thanks
  • 1,272 posts
Posted April 30, 2017 - 10:58 PM
How long do you reckon a vh70 techumseh with some modifications would last with one of those turbos?
:hijacked:
Edited by 637Yeoman, April 30, 2017 - 11:00 PM.
#43 Cvans ONLINE
  • 7,289 Thanks
  • 6,377 posts
Posted May 01, 2017 - 12:17 AM
Long enough to blow up?
#44 637Yeoman ONLINE
637Yeoman
  • 1,570 Thanks
  • 1,272 posts
Posted May 01, 2017 - 08:22 AM
Most likely, i want to do something cool like that to some engine..
  • Cvans said thank you
#45 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted May 01, 2017 - 04:44 PM
Yoeman putting a turbo on a float type carb requires a air tight box that encases the complete carb otherwise you blow the fuel out of the bowl. Also not sure a single cylinder moves enough exhaust to spin a turbo...
  • Cvans and 637Yeoman have said thanks
