#1
OFFLINE
Posted January 02, 2017 - 01:09 PM
Thanks!
#2
OFFLINE
Posted January 02, 2017 - 02:16 PM
There is nothing special about the pulleys on mine. They appear to be standard idler pulley type, and I believe that they are original to the blower.
#3
ONLINE
Posted January 02, 2017 - 03:34 PM
#4
OFFLINE
Posted January 02, 2017 - 05:27 PM
Would you mind sending some pictures?
My issue in not with the pulley, but with the cable binding where they intersect each other at the base of the chutes
so I'll chime in here to ask a few questions about the cable also. first off, is there someone reproducing these cables now? I need both of the chute related ones, the one for chute turning and also the one that adjusts the height or angle the chute launches snow. I'm not planning on using this blower on my ht20 but if I can locate the cables I may just fix it for another future purpose. Unless there's anyone wanting an excellent parts blower, I'd sell it also.
Not to my knowledge, but I can show you where I came up with for the chute turning cable and I am going to be installing an electric actuator for the chute cap adjustment.
#5
OFFLINE
Posted January 02, 2017 - 11:15 PM
I found a long housed cable at my local auto parts store that I will someday use for the adjustment of the chute cap. It has a T-handle on one end and is the twist-lock type so it will hold position. I think it is similar in intent to the factory version, but I will also need to fabricate a mounting bracket for the left side of the dash tower. I got the blower, but the seller did not have all of the necessary extras.
