Hydra16
32 replies to this topic
#1 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 01, 2017 - 09:01 PM
I got a Hydra 16 with deck.in a package deal all or none. He said! A 73 wards with deck and tiller drive shaft, and either a 66 or 67 JD 112 round fenders all 150$ got the wards running today. The MF 16 has a bad starter got a starter that looks similar will put picture tomorrow. Is worth keeping looks a little ruff I have dual ag tires I was thinking of putting on another wards I have. but 4 ag tires on the back of this would be cool!
  • DMAX, limebuzz, 101 senior and 5 others have said thanks
#2 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted January 01, 2017 - 09:22 PM
Too bad your so far away, I'd be happy to get that 16 from you.
Eric
  • DMAX said thank you
#3 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted January 01, 2017 - 09:23 PM
That's a great deal! I think it would look pretty tough with duals on it. Can't wait to see it.
  • dropped82 and KBuzz have said thanks
#4 DMAX ONLINE
DMAX
    Addicted
  • Site Supporter
  • 592 Thanks
  • 235 posts
Posted January 01, 2017 - 09:26 PM
Eric
I agree, I'm even farther away than you!!
#5 ducky OFFLINE
  • 2376 Thanks
  • 4343 posts
Posted January 01, 2017 - 09:38 PM
Good deal. Just that Oregon is a bit to far.
#6 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 01, 2017 - 10:52 PM
I just called someone who has a rebuilt k341. With low hrs,and if I can. Find parts. Have you all ever herd of Steve Johnson here in oregon was on classic tractor feaver he told me to come over and see what he got last summer he has just about everything will do more checking this week a see were to go from here. Duels on a 112????
#7 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 02, 2017 - 07:15 PM
Well checked on that motor. Wrong kind newer 17.5 kohler command. Th p.o. told that I would not do anything and zero compression. I think was just turning the pto that spins free and that it's just the starter That is shot?? I know just thought of it as soon as I posted it ran outside turned the flywheel with a big screw driver and got I got compression !!!
Edited by Casinojim, January 02, 2017 - 07:40 PM.
  • dropped82 said thank you
#8 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 04, 2017 - 10:59 PM
Was going to get the JD112 this weekend,but ice storm coming. if I could get better than the 150$ from 1 of the tractors. I'd be happy. Still on the hunt for a starter for it but I found this online:::::::This is my 1976 Massey Ferguson MF-16, they were produced for 18 months and out of the 3900 or so units made, as many as a third went to Canada or overseas, Massey being a European endeavour. Massey never actually produced any garden tractors themselves, they contracted the work out. These units were built by AMF in West Des Moines Iowa and were the last of a ten year run of the MF series featuring both lawn and garden tractors of 7 to 16 horsepower.....that changes things. Better than 200$ LOL
Edited by Casinojim, January 04, 2017 - 11:20 PM.
#9 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 06, 2017 - 01:46 PM
 if that is true that seams to be a low production number for my MF 16.  and not that many are in the US let alone here in oregon. i just took another look at it setting next to the wards that i got with, its almost twice as big and seems to be built like a tank !! would this be a good candidate for a bucket ?? if so what kind???? I called a garden tractor collector here in salem oregon asking if he had a starter he told me that he does not have 1 in his collection and from what i've seen on classic tractor fever he has ALOT!! I got to get over to his place and see them! any more information on this tractor would be great  thanks again to everyones input
#10 KennyP ONLINE
  • 53258 Thanks
  • 53342 posts
Posted January 06, 2017 - 02:01 PM
If that is a 'high-mount' starter ( mounting bolts below the starter), check here.
#11 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted January 07, 2017 - 02:06 PM
Those starters are everywhere and used by multiple manufacturers. That 16 would easily handle a loader. It has a 2 speed peerless rear with a sunstrand pump. Definitely a tank. I drag logs with mine quite a bit. Can't stop it. I also pulled a Brinly 12" with it at plow days. Doesn't really grunt much doing that. If it were me, I'd keep that 16 around for sure. You did great if you would've just given 150 for the 16.
Eric
#12 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 07, 2017 - 05:17 PM
If the p.o. can't find the panels with the model tag. What then only found. The motor tag K341S spec #71120a and tranny tag model 90-1155 serial # 04- pd 38083
#13 esbbent OFFLINE
esbbent
  • 552 Thanks
  • 367 posts
Posted January 08, 2017 - 09:24 AM
The panel for the left side of the machine will be the one with the model # and serial # for the tractor, which is the more important of the two panels. The right panel can be replaced with a panel off of a Model 16 or 14, both model used same sheet metal. The two things you have going for it now to say it is a MF16 is hood decal and the engine tag with that spec #.
  • Casinojim said thank you
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted January 08, 2017 - 11:53 AM
All MF16 came with rubber engine mounts,  MF14 came with solid engine mounts.
Sure fire way to tell.
  • ducky, dropped82 and My3kidsfather have said thanks
#15 Casinojim OFFLINE
Casinojim
  • 165 Thanks
  • 196 posts
Posted January 08, 2017 - 02:38 PM
Looks like rubber to me. Took more close up pictures. Pretty ruff. Gonna save all my beer cans so I can get that. Ultra rare 5000$ head light bezel and some new wire for the hood
  • limebuzz said thank you
