Torque Specs?
12 replies to this topic
#1 JohnDeere110 OFFLINE
JohnDeere110
  • 215 Thanks
  • 91 posts
Posted December 31, 2016 - 10:01 PM
Do the headbolts on a Kohler K181s have a torque specification or does the "hand tight an' then some" rule apply? :D
#2 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted December 31, 2016 - 10:22 PM
Definitely has a torque spec. Don't know off the top of my head, but has a spec. Check the manuals section. Probably find it in there.. Umm it's new years Eve and you're toruqeing a head?? Ha-ha
  • JohnDeere110 said thank you
#3 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted December 31, 2016 - 10:40 PM
Nearest manual I have handy says 200in/lb.
Edited by adamjd200, January 01, 2017 - 02:39 PM.
#4 secondtry ONLINE
secondtry
  • 1,910 Thanks
  • 1,392 posts
Posted December 31, 2016 - 10:58 PM
The manual in the manuals section of this sight says 15-20 ftlbs. I do not know how to post an internal link but if you go to the top of this page and click in the manuals button/ second from the left you should be able to navigate to the manual. you will have to download it.     Don
  • ducky and JohnDeere110 have said thanks
#5 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted December 31, 2016 - 11:01 PM
Ooops, meant to say inch pounds.
#6 dodge trucker ONLINE
dodge trucker
  • 2,457 Thanks
  • 3,137 posts
Posted January 01, 2017 - 10:01 AM
Nearest manual I have handy says 200ft/lb.
not FT/lb but IN/Lb.    You will not get to 200 FT/lb, the threads in the block will strip or the bolts will snap off way before you get there.
#7 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 01, 2017 - 11:07 AM
See po#5, I corrected myself.
#8 glgrumpy OFFLINE
  • 8,623 Thanks
  • 7,926 posts
Posted January 01, 2017 - 01:34 PM
Bigger K engines are not that hard, think 35lbs but in two increments as you go. AND, a certain pattern is to be followed.  SO, think smaller ones could be less it seems. A manual for that engine should have both pattern and amount in the pages of how to remove/install head.
#9 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 01, 2017 - 01:39 PM
DON'T DO THAT!!!!  20 would be more like it. Let me post the Manual.
#10 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 01, 2017 - 01:41 PM
Here you go.
http://gardentractor...service-manual/
  • JohnDeere110 and secondtry have said thanks
#11 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 01, 2017 - 02:39 PM
And again see post#5, where I corrected my self! BTW, I am editing my first post.
#12 KC9KAS OFFLINE
KC9KAS
  • 5,391 Thanks
  • 4,693 posts
Posted January 01, 2017 - 05:56 PM
200 inch pounds = 16.6666666 Foot Pounds.
Right in the 15-20 FT/LB range.
SORRY, I didn't read every post....my bad.
Edited by KC9KAS, January 01, 2017 - 05:58 PM.
  • adamjd200 and JohnDeere110 have said thanks
#13 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 01, 2017 - 06:19 PM
No problem, it just surprised me how quick everyone jumped on a mistake that I had already acknowledge.
