Wards tractor .what year?
27 replies to this topic
#16 jimmy G ONLINE
jimmy G
  • 909 Thanks
  • 613 posts
Posted January 01, 2017 - 10:26 AM
i would guess it at a 1972 if it has the starter/ generator. 1973 if it doesnt.
apology's for my apparently New bad habit (parroting)
#17 jimmy G ONLINE
jimmy G
  • 909 Thanks
  • 613 posts
Posted January 01, 2017 - 11:26 AM
Good looking tractor. I have a hydraulic pump that came off one of these. Could you get me the diameter (close) of the pulley driving the pump? I want to keep that ratio right when I use it.
I got it this color In a can,it is M/W I swear lol
#18 KennyP ONLINE
  • 34,212 Thanks
  • 43,330 posts
Posted January 01, 2017 - 11:35 AM
So it's a 2" dia. pulley?
I plan to run the pump with an 8 HP Kohler and need to know the pulley ratio. The one on the pump is 4" dia. So it looks like it is running at 50% of the engine speed. I don't plan to run the engine at a high RPM. This will just be a way I can test hydraulic equipment with hooking to a tractor.
#19 drbish OFFLINE
drbish
    Collecter
  • 1,464 Thanks
  • 1,295 posts
Posted January 01, 2017 - 11:53 AM
Running boards r home made.turns over no spark, I will get points and condenser next year ha ha ... good thing I got a parts tractor that came with other one I got. can anyone give me the year of the tractor in the last. 2 pictures and parts tractor was a package deal. Also came with a front scoop. But missing retainer plate. I would like to get/ make one What does it look like??? Added pics of the scoop missing the retainer plate
Your 33145A is a 1972 this is the manual it is in.It is showing it as a 15 hp
http://gardentractor...s-tractors-ipl/
Edited by drbish, January 01, 2017 - 11:57 AM.
#20 PGHsteelworker OFFLINE
PGHsteelworker
  • 95 Thanks
  • 54 posts
Posted January 01, 2017 - 01:20 PM
I can verify that the drive pulley on the driveshaft is 2" and the pump pulley is 4".
#21 gopher OFFLINE
gopher
  • 711 Thanks
  • 730 posts
Posted January 01, 2017 - 01:31 PM
I think your problem is tag switching. All though they appear to been on for long time. I was told a while back that on the x serial numbers switch first two numbers before the x for date. Your last two photos the hood looks early 75 . That said check motor code for date. See if 75 or late 74.
#22 Casinojim OFFLINE
Casinojim
  • 94 Thanks
  • 111 posts
Posted January 01, 2017 - 07:13 PM
Got going cleaned up the points and regap. Briggs model 26437 type 0135-03 code 7311211 Going to have to sale 1 or 2. Is 9 to many
#23 KennyP ONLINE
  • 34,212 Thanks
  • 43,330 posts
Posted January 01, 2017 - 07:29 PM
I have nearly twice that many!
#24 jimmy G ONLINE
jimmy G
  • 909 Thanks
  • 613 posts
Posted January 01, 2017 - 10:08 PM
ummm your talking to the wrong crowd,that's not a question,boarder line profanity in some circles,I don't even know how many I got,pics if you want to see how bad it can become
#25 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,076 Thanks
  • 1,596 posts
Posted January 01, 2017 - 10:33 PM
I base my limit on what I can fit inside. I refuse to leave any outside. I'm up to 12 I think 😆😆😆😆
Eric
#26 jimmy G ONLINE
jimmy G
  • 909 Thanks
  • 613 posts
Posted January 02, 2017 - 01:01 AM
you are a smart man,wish I could think like that,unfortunately my friend recently informed me that a good deal could be had on his dad's old sawmill(dang it,dang it,dang it)now I can collect even more badly needed outbuildings,I'm sure I can fit it in during Hay season (NOT),should probably inform the new addicts about the vast amounts of time giving air compression treatments to keep a hord of dry rot alive (but that is another topic)
  • KennyP and dropped82 have said thanks
#27 Casinojim OFFLINE
Casinojim
  • 94 Thanks
  • 111 posts
Posted January 11, 2017 - 03:29 PM
I am missing the retainer plate
#28 Casinojim OFFLINE
Casinojim
  • 94 Thanks
  • 111 posts
Posted January 12, 2017 - 09:46 AM
Does anyone have one of these
