Using an AC BGB for a rock shaft
6 replies to this topic
#1 KennyP ONLINE
  • 36,486 Thanks
  • 44,954 posts
Posted December 31, 2016 - 07:47 AM
I have a BGB (Bevel Gear Box) from an AC 716 6-speed tranny, Thinking about hooking a Char-Lynn hydraulic motor (have 2) to it to make a powered rock shaft for a lift. I need to get the hydraulic motors out and make sure they work okay.Just wondering if this sounds feasible.
I can't find the pics of the motors. Not sure where they are. May be on my other hard drive.
  • sacsr, Traill95 and boyscout862 have said thanks
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,313 Thanks
  • 1,733 posts
Posted December 31, 2016 - 08:46 AM
I wouldn't see why not. I'd imagine they'll hold some weight too. Considering the torque they see while working the machine. I'm guessing the ratio is 1:1? You may not get much torque multiplication but you won't lose any either.
Eric
#3 dropped82 ONLINE
dropped82
    Nut Case
  • 2,313 Thanks
  • 1,733 posts
Posted December 31, 2016 - 09:35 AM
Might consider using something like a lovejoy to attach the 2.
Eric
#4 KennyP ONLINE
  • 36,486 Thanks
  • 44,954 posts
Posted December 31, 2016 - 09:40 AM
I can gain torque from the arm length out each side. I have to get my spare pump hooked to the 8 HP Kohler as a test unit. Thinking of using a chain coupler to attach the hyd. motor to the input shaft of the BGB. I can get that coupler from Surplus Center. I can use the bolt holes in the front of the BGB to mount the motor to.
#5 boyscout862 ONLINE
  • 12,177 Thanks
  • 8,893 posts
Posted December 31, 2016 - 09:45 AM
I don't like the idea. BGBs are precious and not made for the kind of torque that a lift may encounter. The tension on the BGB is only what the belts put on it. If you used the BGB with a small sprocket and a chain going to a shaft with a big sprocket then it might be okay. I worry that you are going to put time and money into something that wont last. Good Luck, Rick
#6 KennyP ONLINE
  • 36,486 Thanks
  • 44,954 posts
Posted December 31, 2016 - 10:02 AM
That's the kind of info I was looking for, Rick. This is all just my thoughts right now. From what I can tell, this one is in good condition. I'd be happy to pass the whole rear end on to someone, but shipping would be a killer. That thing is heavy!
#7 SimplyRad OFFLINE
SimplyRad
  • 984 Thanks
  • 759 posts
Posted December 31, 2016 - 10:55 AM
On a manual tranny and doing heavy work does put a lot of torque on the BGB. I found out last spring when I got my 3410 stuck in the mud without the lift hooked to mower and trying to back up. Sure was load when it let go.
