Wheel spacers
20 replies to this topic
#16 Greasy6020 ONLINE
Greasy6020
  • 1,306 Thanks
  • 1,267 posts
Posted December 30, 2016 - 11:24 PM
With out pics Im wondering if you can raise fender the 1/2" you require, is that possible?
I think so. What I need to do, is shift the tire/rim/hub assembly 1/2" to the outside of the axle.
It is rubbing on the inside, against the sheet metal protecting the fuel tank. I'll get pictures tomorrow.
Second pic is me pointing to the problem area, that is between the wheel/chains and the fuel tank.
Probably should have said, this is on a roper rt 16 post-78477-0-68474700-1483208544.jpg
As per usual... can one of the kind moderators flip the picture around?
Edited by KennyP, January 01, 2017 - 12:07 PM.
Adjust Gravity
#17 Greasy6020 ONLINE
Greasy6020
  • 1,306 Thanks
  • 1,267 posts
Posted January 01, 2017 - 11:51 AM
Bump, finally added pictures to help explain my problem
#18 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 01, 2017 - 12:12 PM
That there for a reason.
I would move the hub carefully.
  • Greasy6020 said thank you
#19 Greasy6020 ONLINE
Greasy6020
  • 1,306 Thanks
  • 1,267 posts
Posted January 01, 2017 - 05:10 PM
Ok, I'll do that after supper, if I'm sneaky enough getting outside. Grandparents are coming over for dinner.
KennyP, thanks for repositioning those pics!
  • MH81, KennyP and backwoods have said thanks
#20 EricFromPa ONLINE
EricFromPa
  • 3,384 Thanks
  • 3,015 posts
Posted January 01, 2017 - 07:48 PM
I had the same problem when I put a set of calcium loaded 23x9.50 12 Cub Cadet rims and tires with chains on my old ratty SS16. Back spacing is roughly 1" deeper on the Cub rims.
Sears SS16 have press molded fenders so there is a tiny bit more room than your ropers fabricated fenders have,but the Cub rims would not clear the tank bulge with chains on.I had a Craftsman GT5000 parts machine with some decent tires on so I used the rims and tires off of that.
Is this on this 16hp Roper built Moto Mower you was looking at getting back in October?
post-78477-0-63059300-1476300496_thumb.j
Those do look like Cub Cadet rims.
Edited by EricFromPa, January 01, 2017 - 07:49 PM.
#21 Greasy6020 ONLINE
Greasy6020
  • 1,306 Thanks
  • 1,267 posts
Posted January 01, 2017 - 08:24 PM
That's her.
I made good progress. I slid the hub 1/2" out from where it was. Gonna go do some "testing" tomorrow, in the snow.
