Cannot mount a tire to save my Tail
34 replies to this topic
#31 MH81 OFFLINE
  • 29,970 Thanks
Posted December 29, 2016 - 07:01 PM
Yeah, BOBcat385b sounds weird
  • 29 Chev said thank you
#32 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 9,405 Thanks
  • 3,085 posts
Posted December 29, 2016 - 07:11 PM
A cat without a tail trying to mount tires
Might be like a squirrel playing on hydro wires
Things may be great as long as attention is paid
And the squirrel carries on with the plans that he's made
But touch something wrong or step in the wrong spot
And the dance that will follow could be hot, hot, hot !
  • MH81 and LilysDad have said thanks
#33 Mtypython OFFLINE
  • 355 Thanks
  • 346 posts
Posted December 29, 2016 - 08:18 PM
use pb blast and 2 spoons little bites, thats what i use when i have to do a big truck tire
#34 larrybl ONLINE
    Texas Member
  • Site Supporter
  • 7,101 Thanks
  • 4,454 posts
Posted December 29, 2016 - 09:57 PM
I held my comments on this as I have been down this road often. I learned the hard way, as I hope you have, that there is a certain way the tire has to be put on the rim. Windex is a great helper. I place mine on the floor and use a knee to press one side down while prying the tire over the rim. Now is the time to check if the tread pattern is correct. Like mentioned before, I had to switch one of my AGS around. I liken mounting tires to wrestling alligators!
Breaking the bead, fixed I have a bead breaker now
Removing the tire from rim, Worst case use a sawsall.
Mounting the tire, discussed above
Inflation, Can be a bear, Straps, more straps, and globs of grease.
#35 Cjet69 OFFLINE
  • 576 Thanks
  • 318 posts
Posted December 29, 2016 - 11:08 PM
I use tire mounting compound in paste form. I can often push the first bead over the rim. Several of or local tire shops have just given us a can full when needed. It works way better than soap.
