Cannot mount a tire to save my Tail
34 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted December 29, 2016 - 01:05 PM
I have HF tire changer and cannot mount this tire to save my life. Finally got the bottom on, but am bending the bar trying to stretch the top onto the rim.
29x12x15 tires going onto a 15x10 rim, same size of tire that came off it.
I need some ideas.
#2 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 29, 2016 - 01:12 PM
Is the tire cold? Looks like you have plenty of lube on there.  I have the HF changer, but it's bar is about 4' long. I usually just use two good tire spoons. But I will put a pair of vise grips on the rim to hold the tire from spinning and slipping back off.
  • Cat385B and propane1 have said thanks
#3 shorty ONLINE
shorty
  • 5,485 Thanks
  • 5,263 posts
Posted December 29, 2016 - 01:13 PM
Ether baby.
NOT RESPONSIBLE FOR SINGED EYE BROWS OR DAMAGE TO MAN CAVE.
I didn't look close enough at the pic to see that it wasn't fully on yet.
Edited by shorty, December 29, 2016 - 01:37 PM.
  • dogsoldier and michael.kitko have said thanks
#4 Xrperry ONLINE
Xrperry
  • 1,035 Thanks
  • 768 posts
Posted December 29, 2016 - 01:14 PM
if you can get it started on one side make sure you push the tire down before you try to get the rest of it.
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,478 Thanks
  • 1,113 posts
Posted December 29, 2016 - 01:15 PM
When you get to the tight spot push the opposite side down towards the center of the wheel. It will give it more play to get it on
#6 Tecumseh power OFFLINE
Tecumseh power
  • 1,478 Thanks
  • 1,113 posts
LOL we posted the same thing at the same time we must think alike
  • Xrperry said thank you
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Using one spoon to hold the starting point, the red bar is what is pushing the bead over the edge of the rim, but holy cow is it tight.
#8 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,178 Thanks
  • 697 posts
Posted December 29, 2016 - 01:16 PM
Spray windex or similar glass cleaner on the bead of the tire, makes them slip right on. I got this tip from an article in a stock car racing magazine. This was advice from one of the major tire manufacturers, but I don't recall which one.
Jim
Edited by CanadianHobbyFarmer, December 29, 2016 - 01:17 PM.
#9 tater195 ONLINE
tater195
  • 2,197 Thanks
  • 1,412 posts
Posted December 29, 2016 - 01:17 PM
You are working on the hard side. The step on the other side of the rim is closer to the bead. mount that side backwards and slide the wheel through and then do that side.
**edit by "backwards".. I mean start the tire with the wheel sticking out from the tire. the side of the tire you just mounted slides over the big step.
Edited by tater195, December 29, 2016 - 01:21 PM.
  • ducky, MH81, Cat385B and 1 other said thanks
#10 Xrperry ONLINE
Xrperry
  • 1,035 Thanks
  • 768 posts
Posted December 29, 2016 - 01:18 PM
i change tires without a tire changer and what a pain .need to get me one of those while i can still use my hands.lol
#11 Xrperry ONLINE
Xrperry
  • 1,035 Thanks
  • 768 posts
Posted December 29, 2016 - 01:19 PM
tecumseh, my tractor is the same one that you have in the pic.spooky...lol
  • Tecumseh power said thank you
#12 MH81 OFFLINE
Posted December 29, 2016 - 01:20 PM
That's cat for ya.
What was it someone asked recently about someone being born breach...?
#13 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Yep, shoved the part that was on down past where the rim is dished. But to get to that it has to be down over 3". That might be an issue.
#14 tater195 ONLINE
tater195
  • 2,197 Thanks
  • 1,412 posts
Posted December 29, 2016 - 01:27 PM
you talking about getting the bead seated?  Soap it up good and slam it on the ground. it will go enough to get started. air compressor will do the rest. Grab a 1/4"  male air quick connect and put that over the stem with core removed. That should blast it where it needs to go
  • Cat385B said thank you
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted December 29, 2016 - 01:35 PM
Nope, getting the darn tire over and onto the rim.
BTW, I'm using Dawn dish soap for lube, no water.
Edited by Cat385B, December 29, 2016 - 01:36 PM.
