Chainsaw flooding problem, do saws ,,,
5 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,225 Thanks
  • 3,966 posts
Posted December 29, 2016 - 11:45 AM
pressurize the fuel tank to operate. Intermittent trouble with flooding. New carb kit installed. New gas filter and gas line too. Some times, if you take the spark plug out and pull it over a few times it will spit gas out the spark plug hole. So, had it running today and worked, but quit some and rev up and down on its own. But I got some wood cut.
Any ideas other than dirt. Poulan saw.
Noel
#2 tater195 ONLINE
tater195
  • 2,032 Thanks
  • 1,350 posts
Posted December 29, 2016 - 11:51 AM
Does it seem quieter than normal? You could have a plugged up muffler. That will restrict air flow, make it hard to start and not have good throttle response
  • propane1 said thank you
#3 propane1 ONLINE
propane1
  • 8,225 Thanks
  • 3,966 posts
Posted December 29, 2016 - 11:56 AM
No, tater195, had that apart too, not plugged up anywhere in the muffler. Checked the key way on flywheel also, it was ok.
Noel
#4 jimmy G ONLINE
jimmy G
  • 1,132 Thanks
  • 740 posts
Posted December 29, 2016 - 12:36 PM
Check intake,biggest problem on all these saws,if needle,seat and cap vent are good do a compression test,their is a model they made with with floating port inserts I stay away from,they lose down pressure and the crank fills with gas like bad rings or seals can do,when it does come up its instinstant flood
#5 HDWildBill OFFLINE
  • 8,972 Thanks
Posted December 29, 2016 - 12:51 PM
Have you checked for trash in the carb?  I was working on a blower that was doing the same thing and round corrosion in the carb.
#6 Jazz OFFLINE
Jazz
  • 2,189 Thanks
  • 1,356 posts
Posted December 30, 2016 - 02:10 PM
leak in fuel line sucking air??
