Onan 20HP Points box
6 replies to this topic
#1 veizter OFFLINE
veizter
  • 14 Thanks
  • 21 posts
Posted December 28, 2016 - 07:41 PM
I have a 20 hp onan engine .the points box got snapped off and I am searching for options . the box # is  P- 2475 . it is the extension box , like 5 inch's high .I'm looking for another points box just like this , or if a shorter box will work that's ok to . could I put an electronic box on it to replace the points? I have had this engine stored for 30 plus years , time to use it ...
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,525 Thanks
  • 9,820 posts
Posted December 28, 2016 - 07:52 PM
Is this off a CCKA or B?
  • veizter said thank you
#3 veizter OFFLINE
veizter
  • 14 Thanks
  • 21 posts
Posted December 28, 2016 - 07:55 PM
there is no tag on the engine . it's a cast iron block, the starter has the solenoid mounted on it . has the large oil pan, goes right under starter
#4 veizter OFFLINE
veizter
  • 14 Thanks
  • 21 posts
Posted December 28, 2016 - 08:14 PM
looking at pictures , I believe it to be a CCKA .
#5 veizter OFFLINE
veizter
  • 14 Thanks
  • 21 posts
Posted December 28, 2016 - 08:37 PM
this engine came off a tenant floor sweeper . will there be an rpm issue ?
#6 glgrumpy OFFLINE
  • 8,494 Thanks
  • 7,850 posts
Posted December 29, 2016 - 11:34 AM
There is an Onan expert on the Red Square forums that helped me with parts and info. Can't recall name now, but asking there will work. Also fellas on Case forums know them well and may have parts. Little harder to find the parts for them. Ebay has some avail, but have to watch for quality I was told. Get yourself a parts book or download for your model and compare things in them to what you have.
#7 KennyP ONLINE
  • 36,451 Thanks
  • 44,940 posts
Posted December 29, 2016 - 12:02 PM
I'll send you a PM. Look upper right by your screen name for it to show.
