Throttle creep/plow suggestions
7 replies to this topic
#1 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 03, 2011 - 06:00 PM
I find that when I put the throttle wide open it creeps back to a lesser rpm. i have some ideas but what to know what is the best fix for this.
also what is the best plow for this tractor? (MF 12. ) I have a old horse drawn plow that I could try to convert.
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 03, 2011 - 07:40 PM
The rivet (center pivot) on the throttle control needs to be tightened up, you can remove the control and peen it over with a hammer and punch or if your real careful you can squish it with a pair of vise grips or large channel locks.
#3 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 03, 2011 - 08:13 PM
that was My thought also, thanks
#4 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted June 04, 2011 - 07:06 AM
I just looked thru your Craigslist, It's pretty lite on Brinly stuff. Can't believe there isn't any.
I would put up a couple of ads in the areas you'd be willing to drive to. It's free & may get you what you need without having to build/tweak/repeat.
#5 Justpics OFFLINE
Justpics
  • 10 Thanks
  • 129 posts
Posted June 04, 2011 - 11:55 AM
I think most of the tractors are on the east coast. so not much here for the small stuff. and I don't need a 20 bottom plow!!
#6 NUTNDUN OFFLINE
  • 10445 Thanks
  • 15622 posts
Posted June 04, 2011 - 04:16 PM
If trying to tighten the rivet doesn't work you can always drill it out and put a bolt and two nuts on along with some loctite to keep the nuts locked in place once you get it at the right tension.
#7 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted June 04, 2011 - 07:19 PM
I don't know how far from you this is, but it looks pretty new...
Plow System For Garden Tractor
#8 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted June 04, 2011 - 07:21 PM
or maybe he'd just sell the plow on this one?
2007 Craftsman D.G.S 6500 Lawn and Garden Tractor Bagger & Empliments
