Replacing the starter generator belt MW Hydrostatic 14 1970
6 replies to this topic
#1 Angus in Wyoming OFFLINE
Angus in Wyoming
  • 13 Thanks
  • 8 posts
Posted December 25, 2016 - 09:30 PM
Thanks for all the help with my other questions.  I feel badly that I seem to be controlling the questions for the time being.
Now my question.  I need to replace the belt on the starter generator.  It is looking rough and is either the wrong size or stretched out too much.  I run out of adjustment before it gets tight and I still get some slippage at times.
The drive line to the transaxle needs to come off so I can remove and replace the belt.  I have the four bolts taken out of each end of the driveline off but it won't slip apart.  Have any of you done this job?  Do I have to take the transaxle out to do this?
Thanks again for your help.
Merry Christmas and Happy New Year
Angus
#2 haykarenhardy OFFLINE
haykarenhardy
  • 56 Thanks
  • 30 posts
Posted December 26, 2016 - 05:31 AM
If its a Simplicity made MW, there should be a collar that is set screwed to the Bevel Gear box, break loose the set screw and work collar back.(this is how you move the assemble on 7000 series, there may be a manual on this site for B models)
  • boyscout862 and Angus in Wyoming have said thanks
#3 Angus in Wyoming OFFLINE
Angus in Wyoming
  • 13 Thanks
  • 8 posts
Posted December 26, 2016 - 08:48 AM
It is a Gilson.  There is a keyed collar on the transaxle end, but I cant get it to move.  I don't think it has moved in 45 years.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted December 26, 2016 - 10:16 AM
We have a 1970 GILSON S-14 H....I think it is the same tractor that you have.....
I did not have any luck moving the collar on the transaxle either, but we had the engine off for a complete restoration.
I wouldn't beat or pry on the collar, as it may damage something in the transmission.
You can remove four 3/8" bolts that hold the engine to the oil pan and move it forward, but then you will need a new oil pan gasket.
I can't give you any help for this issue, but if you come up with ideas, please share them!
Edited by KC9KAS, December 26, 2016 - 02:14 PM.
  • Angus in Wyoming said thank you
#5 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted December 26, 2016 - 10:59 AM
Depending on size go with a link v-belt. Some places sale by foot.Just have to do some looking to find what will work for you. Being a straight in line pulleys should last a long time. They can be little pricey if sold in long sections.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,381 Thanks
  • 10,146 posts
Posted December 26, 2016 - 11:41 AM
As stated above, I would move the engine to get it on.
#7 Angus in Wyoming OFFLINE
Angus in Wyoming
  • 13 Thanks
  • 8 posts
Posted December 27, 2016 - 01:42 PM
Well gang I got the belt off.  I don't have an oil pan gasket and I can't seem to figure out how to order parts for my engine.  I guess I should use one of the site sponsors.
Instead I put jack stands under the axle, took off the u-bolts, one other mounting bolt, and disconnected the parking break arm and forward-reverse lever (at the transaxle).  I then jacked the frame about an inch from the axle and I was able to wiggle the drive shaft out.  Easy peasy.
When I go to town will try to find a replacement belt.
Thanks again for the help and ideas.
Angus
