OK now I did something stupid
13 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted December 22, 2016 - 07:35 PM
I was putting the battery in my suburban 12 ,I turned the key and it turned over. I put the battery hold downs on and noticed I had the cables switched !
I put them back right and it turned over and started it. There was no sparks or burnt wires anywhere but did I fry something?
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 22, 2016 - 07:43 PM
You can fry the charge coil on the stator very easy like that on a Tecumseh Being that it still runs it should be ok. Does it have a starter generator? Or a regular starter? The ignition system is different. on the hh120 with a starter generator. The one with the starter generator you probably won't hurt anything
Edited by Tecumseh power, December 22, 2016 - 07:51 PM.
  • Alc and Xrperry have said thanks
#3 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted December 22, 2016 - 07:51 PM
It's a starter generator
  • Tecumseh power said thank you
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 22, 2016 - 07:53 PM
I think you will be ok. I couldn't remember if the ss12 had a generator or not
  • Xrperry said thank you
#5 Lmiller3358 OFFLINE
Lmiller3358
  • 1,568 Thanks
  • 1,469 posts
Posted December 22, 2016 - 08:41 PM
Should be fine, my buddy did that on a newer Craftsmen this past spring and fried the starter relay !
#6 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted December 22, 2016 - 09:25 PM
Throw a meter on it and make sure it's charging (if it's got an ammeter you can see it there too).  If it's charging find something else to worry about.
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted December 22, 2016 - 09:38 PM
Does the red light go out?
Apart from frying something, the generator can be polarized wrong that way. On the upside, powering the starter should re polarize it correctly.
#8 toppop52 OFFLINE
toppop52
  • 5,594 Thanks
  • 4,940 posts
Posted December 22, 2016 - 09:52 PM
"OK now I did something stupid"
Yes you did! But you have a lot of company, we've all done it.
  • MH81, Alc and Xrperry have said thanks
#9 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted December 22, 2016 - 10:21 PM
The red light don't work at all now maybe cooked it.
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted December 22, 2016 - 11:14 PM
That's not good.
Put a meter on the battery.
After it starts, it should come up to 14ish volts.
If not, time to do some troubleshooting
#11 chieffan ONLINE
  • 11,763 Thanks
  • 7,276 posts
Posted December 23, 2016 - 08:10 AM
Easy enough to do when you get a tractor with two black cables.  I put red tape on the positive cable for about 3" from the battery clamp.  Saved my butt a few times.
  • MH81, Alc, ericjr16 and 1 other said thanks
#12 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted December 23, 2016 - 12:13 PM
Yep mine have 2 black cables and I have a roll of red tape, was going to wrap the positive cable before I took it apart, but forgot to do it, thought I knew witch one was positive. Its wrapped now.lol
Edited by Xrperry, December 23, 2016 - 12:14 PM.
#13 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 23, 2016 - 07:49 PM
I bought a panzer one time with a 10hp Tecumseh I took it home and put a battery in it and instantly ruined the stator. Someine replaced the cables and put a red one to the chassis ground and a black one to the starter solenoid. I should have looked first but who would have thought.
  • MH81 and Xrperry have said thanks
#14 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted December 24, 2016 - 11:24 AM
Yep something so simple can really booger things up.
