Time to Enter Tractor of the Month!
P K 1614 - need an education on front blade/plow
27 replies to this topic
#1 eastcreek OFFLINE
eastcreek
  • 27 Thanks
  • 29 posts
Posted December 19, 2016 - 08:51 PM
I've got a 1976 1614 and would like to start looking for a snow plow for it.
I'm unclear about what will actually fit this tractor. It sounds like there are several versions but not all will fit correctly. Can anyone guide me through how to identify the right blade assembly for a 1976 1614? I've seen several on CL but some listings state that they will only fit pre 1973 tractors and some only Jim Dandy but I don't know enough to be able to tell from the photos. Also if anyone has a photo that shows one mounted or all the attaching hardware that would be great.
Thanks,  Roger
#2 classic ONLINE
classic
  • 3,746 Thanks
  • 1,717 posts
Posted December 19, 2016 - 09:22 PM
This link explains things well regarding the plow that you need. The pics were a big help to me when I had the same question that you are asking.
http://www.mytractor...age=2&_k=4pqcnq
  • KennyP, TomLGT195 and eastcreek have said thanks
#3 classic ONLINE
classic
  • 3,746 Thanks
  • 1,717 posts
Posted December 19, 2016 - 09:29 PM
In that thread it shows this picture. This is the plow that you need for your PK.
#4 eastcreek OFFLINE
eastcreek
  • 27 Thanks
  • 29 posts
Posted December 19, 2016 - 10:29 PM
Thanks!
#5 classic ONLINE
classic
  • 3,746 Thanks
  • 1,717 posts
Posted December 19, 2016 - 11:03 PM
You're welcome. I just plowed with my PK for the first time after the last storm, and it does a great job. I was in a bit of a rush, so I didn't get any pics.
#6 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 7,286 Thanks
  • 4,150 posts
Posted December 19, 2016 - 11:50 PM
:tapping_fingers:
  • KennyP, TomLGT195 and classic have said thanks
#7 Alc ONLINE
  • 5,806 Thanks
  • 6,817 posts
Posted December 20, 2016 - 06:26 AM
Is this the plow eastcreek  needs ?
http://allentown.cra...5922360963.html
  • classic and eastcreek have said thanks
#8 KennyP ONLINE
  • 30,355 Thanks
  • 40,997 posts
Posted December 20, 2016 - 06:36 AM
Probably.
  • classic said thank you
#9 classic ONLINE
classic
  • 3,746 Thanks
  • 1,717 posts
Posted December 20, 2016 - 08:01 AM
Here is a pic of the tabs/ mounting brackets on the frame for the 73 to 80 something plows. Also, here is a pic of the correct plow that I picked up for mine, but it has an adapter bracket assembly for mounting these plows on the pre 73 PK's. I just removed the adapter bracket assembly and mounted the plow on my PK. This adapter bracket assembly is original equipment.
Kris, I would have taken pics when I plowed, but I drained the gas from another machine and ended up with water in my fuel system. I had to completely drain the fuel systems in my PK and Allis Big Ten, plow 600 feet of driveway, then go clear the snow at my Mom's place. I finished up just as the sun went down. The PK did a great job, and I'll get some pics during the next storm. I didn't quite finish the PK before winter, but I'll be finishing it in the spring. At least I can use it to haul firewood and get the plowing done. We have some good weather this week, so I can make up some tire chains that I will surely need when deeper snow comes. The PK sure hauls a good load of oak, though!
  • Gtractor, KennyP and eastcreek have said thanks
#10 eastcreek OFFLINE
eastcreek
  • 27 Thanks
  • 29 posts
Posted December 20, 2016 - 10:12 AM
That would be perfect! I just wish it was a little closer, 3 1/2 hours each way isn't going to happen this week.
#11 David Brown OFFLINE
David Brown
  • 4,505 Thanks
  • 2,423 posts
Posted December 20, 2016 - 10:26 AM
This is what he needs.
 Even though it's a Jim Dandy in the picture, it's the same basic hookup.
Edited by David Brown, December 20, 2016 - 10:28 AM.
#12 eastcreek OFFLINE
eastcreek
  • 27 Thanks
  • 29 posts
Posted December 27, 2016 - 12:24 PM
 My son and a friend decided to take a road trip yesterday.
The chains look fine, the blade is a little rougher than I'd like but it should work fine although I'm not sure if the lift rod is correct. The mower deck is pretty rough but looks like it has the parts that are missing from my good deck shell. I'm not up to speed on PK parts but he ended up parting with $275 for this. I hope all the important pieces are here.
  • Gtractor and Alc have said thanks
#13 eastcreek OFFLINE
eastcreek
  • 27 Thanks
  • 29 posts
Posted January 05, 2017 - 08:33 PM
Tried mounting the plow this afternoon. The lift rod is home made and I've got it working but does anyone have a good photo and dimensions of the factory lift rod for a hydraulic lift? I ran out of light for today but still want to put a horse mat edge on it and see if the chains fit.
Front end.
Back end.
#14 a.graham52 OFFLINE
a.graham52
  • 115 Thanks
  • 126 posts
Posted January 09, 2017 - 06:53 PM
Lift rod looks fine to me. Whats your concern
#15 eastcreek OFFLINE
eastcreek
  • 27 Thanks
  • 29 posts
Posted January 10, 2017 - 07:58 AM
I thought the factory rod had some type of slide and spring gizmo to allow for a bit of "float". Will leaving the hydraulic valve in the float position be sufficient to avoid breaking or bending something in certain situations. On my old Cub Cadets I used to use chain instead of lift rods for the snow plows and that worked great.
