Long time question I need some electrical guy to answer.
8 replies to this topic
#1 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 18, 2016 - 10:35 PM
I'm not the best with electricity. So help will be appreciated. My question is on these 10 and 20 amp Tecumseh stators, what can be used as a replacement voltage rectifier? I think if I remember correctly. The 10 amp puts out about 42 volts AC. If I wanted to use a different type regulator/rectifier. What would the specs be if I was looking. For a replacement? 10 amp or 20 amp 12v ? Or what are some options off other machines? I'm tired of all my suburbans not charging. And I'm not paying 75 for a used one. When there is new regulators. To be had on ebay for 10 or 20 bucks. Just need to know the specs i would need to look for . I'd like to use my headlights and not just use the battery for starting. What have you guys used? I can mount it on the tractor it doesn't have to be on the blower cover like the factory ones.
#2 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted December 19, 2016 - 01:08 AM
So many variables. So many years since trades training.  So little Captain Morgans.  If it is 42V ac peak to peak, then running it through a bridge rectifier gives you 21 vac p2p.  A good filter would give you 70% of that as DC (14.7 vdc).  In theory, any 12 volt car or GT regulator should work.  My Allis uses a Delco -Remy.
  • Tecumseh power said thank you
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 19, 2016 - 01:11 AM
So if I get a 12v small engine one on ebay do I get the 20 amp one of its a 20 amp system?
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 19, 2016 - 01:13 AM
Or could I use this one on the 10amp stator the amps confuse mehttps://www.dbelectr...r-IAaAowf8P8HAQ
#5 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted December 19, 2016 - 08:17 AM
The amp rating on the regulator/rectifier will be how much current it can handle before releasing its magical blue smoke.  To be safe it should be rated as high or higher than the stator.
So you should be fine with a 15 amp regulator/rectifier on a 10 amp starter but it might well die young with a 20 amp stator.
  • propane1 and Tecumseh power have said thanks
#6 TAHOE ONLINE
TAHOE
  • 8,336 Thanks
  • 5,818 posts
Posted December 19, 2016 - 10:08 AM
It doesn't matter that it looks like the original, as long as it has AC/B+/AC outputs, you are fine.
I run the cheapie Onan 20 amp ones off ebay on my Sears 20 amp system, I think I paid $11 for the last one I bought. I use a winch pretty heavily for snow plowing so I usually burn one up if plowing snow for a long time, but they hold up well during normal use.
Just search Onan regulator of John Deere regulator on Ebay
#7 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 19, 2016 - 10:59 AM
Thanks guys this was a big help
#8 propane1 ONLINE
propane1
  • 9,727 Thanks
  • 4,509 posts
Posted December 19, 2016 - 11:36 AM
I thought it was magical green smoke that came out, and as my son says, ya can't put the smoke back in.
Noel
#9 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted December 19, 2016 - 12:24 PM
Noel
That'd be metric smoke.  We don't use that here.
  • KennyP, propane1, Leonard VanCamp and 1 other said thanks
