GT19 running rough at mid to full RPM
4 replies to this topic
#1 luc.doiron OFFLINE
luc.doiron
  • 34 Thanks
  • 16 posts
Posted December 18, 2016 - 09:56 PM
Good evening gang,
Been working on my tractor lately trying to get it set to hook up the snowblower on it. It was running pretty poorly since I bought it. Installed a new fuel filter, air filter, and just a few days ago we took the points off, cleaned and adjusted them. Tonight I reset the carb as per the service manual and it runs okay up until half to 3/4 throttle, then it starts to sputter. Plugs look alright, might change the fuel filter again since I ran all that old fuel through it. Any thoughts on anything else I should look at? Don't know how it'll run under load, I'll do more trial tests tomorrow. Carburetor was taken apart and cleaned a few days ago too.
Sent from my SM-G870W using Tapatalk
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted December 18, 2016 - 10:23 PM
I think you need to. Lean the mixture with the main jet screw . Turn the throttle up the whole way and turn the screw in until it smooths out.
#3 shorty ONLINE
shorty
  • 5,507 Thanks
  • 5,271 posts
Posted December 19, 2016 - 06:09 AM
Get Jim to stop putting monkey p in the tank.
Had you checked the govenor at all? As in the linkage might be out of adjustment. Had that happen on one.
  • boyscout862 and Gillis.jim have said thanks
#4 luc.doiron OFFLINE
luc.doiron
  • 34 Thanks
  • 16 posts
Posted December 19, 2016 - 10:10 PM
We found the culprit. The points went back out of adjustment. We Re-set it, and tightened it really good. Furthermore I went and bought a new set of breaker points in case the originals fail again. Thanks for the input guys!
  • Wm McNett, KennyP, shorty and 1 other said thanks
#5 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted December 20, 2016 - 09:19 AM
I should check mine too! Doesn't seem to be charging and it's starting to run rough. I've cleaned and set the carb and changed the air filter.
