Part sources?
27 replies to this topic
#16 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted January 04, 2017 - 09:38 PM
When I read your post about u-joints, I was wondering if you knew something that I didn't.
Those are similar to the old pin in block.
Be back in a minute
Sent from my SM-G920P using Tapatalk
  • adamjd200 said thank you
#17 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted January 04, 2017 - 09:44 PM
http://www.mytractor...ad.php?t=936433
Scroll down and you should find a link to my post and how I rebuilt mine.
#18 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 04, 2017 - 10:35 PM
Another thought I just had is to machine the holes out in the yoke to accept a bigger cap, very little a make it so that it can accept a modern u joint.
#19 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 04, 2017 - 10:49 PM
Perhaps a neapco 1-0475, and make a retainer.
Neapco 1-0475 is .75caps by 1.90cross.
  • Wm McNett said thank you
#20 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted January 07, 2017 - 12:17 PM
Look at this on eBay http://www.ebay.com/itm/371694435017
#21 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 07, 2017 - 11:01 PM
Thanks, the only thing bad on that assembly on mine is the two small idlers, I just got my replacements today.
#22 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 10, 2017 - 03:55 PM
Here's what I am dealing with as far as the drive shaft goes, Neapco 1-0475 won't work, too big, a GWB 437.10 would be about right, .591"cap and 1.61 cap to cap, wouldn't have to remove much material.
http://www.drive-lin...ujointchart.htm The u joint I have in mind is the top one.
Here are some pics of my shaft parts,
#23 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted January 10, 2017 - 04:11 PM
Hopefully that $143 price isn't correct 😲
#24 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 10, 2017 - 04:32 PM
Didn't notice that, wish I could find something that small in neapco or something.
#25 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted January 10, 2017 - 05:12 PM
There was a guy building and selling replacement shafts, flanged yoke to 1" 15 spline quick coupler with the 1000 series universals a few years ago for around $380 so I know all the parts to make one are out there somewhere.
#26 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 10, 2017 - 05:14 PM
The small Weasler 02 series, .59" cap by 1.50" cross would work, cheaper too just need the whole part number.
#27 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 10, 2017 - 05:16 PM
We were posting at the same time, I can use my shaft if I have a u joint to use, Weasler would be ideal.
#28 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted January 11, 2017 - 06:10 PM
I think I'm just going to build a new half shaft.
