Part sources?
27 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted December 16, 2016 - 11:18 PM
Where are some good part sources for Ariens products?  My 48" snowblower is going to need several pulleys and I'm not having much luck on ebay.  The model # I got off the tag is 801070, couldn't read the serial #.
Edited by adamjd200, December 16, 2016 - 11:20 PM.
#2 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted December 16, 2016 - 11:28 PM
Got a picture? I'm not finding one with that number.
Sent from my SM-G920P using Tapatalk
#3 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted December 16, 2016 - 11:34 PM
That # could be messed up, I was in a hurry when I read that, no pic right now as it is at a local shop getting some rust damage repaired, it's a front mount two stage that I bought for the front of my S-14H, already managed to find a drive shaft.
#4 shorty ONLINE
shorty
  • 5,922 Thanks
  • 5,453 posts
Posted December 16, 2016 - 11:42 PM
Should be 831_ _ _
I would go to the hardware store, but I doubt you have a Wallyworld sized Paulb a few miles away.
  • adamjd200 said thank you
#5 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted December 16, 2016 - 11:52 PM
Should be 831_ _ _
That's one of the few things I miss about Lancaster Co., there's nothing like that around here, just TSC, and a few local places that are overpriced.
  • shorty said thank you
#6 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted December 17, 2016 - 12:02 AM
I've bought a few pulleys from an electric motor place I found online. Had to bore them or make bushings to fit because they didn't have the correct bore.
Jacks will be expensive.
http://www.jackssmal...-thro-two-stage
And a few othe models
http://www.jackssmal...and-attachments
#7 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted December 17, 2016 - 12:41 AM
There's a pulley that might be the correct diameter on an old junk New Holland hay elevator out behind the barn, should probably look at that, never thought to check an electric motor place, may have to try that.
#8 Bolens 1000 OFFLINE
  • 15,559 Thanks
  • 18,320 posts
Posted December 17, 2016 - 08:58 AM
Alot of Ariens products made today you need to go to a dealer as they make some pretty special parts nowadays
#9 shorty ONLINE
shorty
  • 5,922 Thanks
  • 5,453 posts
Posted December 17, 2016 - 09:16 AM
There are very few parts they can't find.
#10 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted December 17, 2016 - 09:36 AM
Electric Motor Warehouse is where I've bought quite a few pulleys for projects.
Wished I'd found them sooner, might not had spent days making one for the old New Holland.
#11 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted December 18, 2016 - 12:19 AM
This Blower is probably 25-30years old.
#12 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted December 27, 2016 - 10:21 PM
I believe it is a 10" pulley, may have found one from an old tiller that would just need the center hole bored out.
#13 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted January 03, 2017 - 11:28 PM
Got a pulley,have a u-joint on order, should get here tomorrow, gonna order two new idlers tomorrow because they are both bad, welder should be done with it soon, this thing is in worse shape than I originally thought.
#14 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted January 03, 2017 - 11:29 PM
Should be 831_ _ _
Correct model is:
831010
#15 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted January 04, 2017 - 09:33 PM
OK, u joint for the drive shaft, tried the number in the cross reference thread but the caps aren't even close, don't want to completely change the yoke, this has got me pulling my hair out, help!
