1969 John Deere 110 8hp ?
9 replies to this topic
#1 SNOWSLINGER OFFLINE
SNOWSLINGER
  • 2 posts
Posted June 03, 2011 - 12:49 AM
I bought a 110 or a 112 8hp John Deere ( not sure which one ) from a friend and I have been working on it new tires, starter, and little things like that. When I recieved it, it didn't have an ignition key for it. It was just a toggle switch to start it so I tore it apart and tried to get it working the right way, but I haven't been successful finding a wiring diagram for it. Is their anybody out there that can help me with this, it would be greatly appreciated. Thanks
#2 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted June 03, 2011 - 04:57 AM
I apologize about your post being flagged by the system and it shouldn't have. I approved the post.
We have a good many John Deere guys that can help you out. I am not familiar with the wiring on them.
#3 mjodrey OFFLINE
Posted June 03, 2011 - 05:25 AM
Snowslinger,:welcometogttalk:
Glad to have you with us.
#4 poncho62 ONLINE
poncho62
  • 1,725 Thanks
  • 1,655 posts
Posted June 03, 2011 - 05:29 AM
welcome....Not sure about the wiring either, but I believe that a 110 has 10 hp and a 112 has 12 hp.......Someone putting an 8 hp in there may be the reason for the rewiring they did
#5 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted June 03, 2011 - 06:43 AM
Welcome Snowslinger,
Yes a 1969 110 has a 8hp Kohler originally. First thing we need to do is make sure that it is a 110 by using the serial number on the tractor. The 69 110's used a mag type ignition under the flywheel. If yours has a coil mounted ( like used on the older cars ) then it has been coverted over and that has a different wiring harness and key switch. If you could post some pictures of what you have that would help alot. Then we can go from there.
Mark
#6 grnspot110 ONLINE
grnspot110
  • 4,147 Thanks
  • 2,640 posts
Posted June 03, 2011 - 06:48 AM
The early 110's had a 181 Kohler, 8 HP (63's used a 7 HP), later models had a 10 HP Kohler.
Early 112's used an HH100 Tecumseh, later changing to a 12 HP Kohler.
My 74-112 w/10 HP Kohler;
grnspot
#7 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted June 03, 2011 - 06:57 AM
The 1969 110 had a 8 hp Kohler K181 while the 112 had a 10 hp Tecumseh, the 12 hp Kohler was an option for the 112. It wasn't until 1972 that the 110 was offered in both the 8 hp and 10 hp Kohlers.
You can find more info at Weekend Freedom Machines.
I uploaded the wiring diagram that you need here: John Deere 110/112 Wiring Diagram SN 130001-161771 - Manuals - Garden Tractor Talk - Forums
  • JDMonnell and rebel have said thanks
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 03, 2011 - 10:36 AM
[ATTACH=CONFIG]15418[/ATTACH]
grnspot
That's a sweet 112!
  • JDMonnell said thank you
#9 SNOWSLINGER OFFLINE
SNOWSLINGER
  • 2 posts
Posted June 04, 2011 - 02:00 AM
Tmo, Thank you very much you have no idea what google searches have pulled up that tractor or maybe you do. lol That should help out a great deal and I will post the results. Thanks, Snowslinger
#10 JDMonnell OFFLINE
JDMonnell
  • 2 posts
Posted June 09, 2011 - 11:57 AM
Those documents help out newbies like me tremendously! Thanks!
