Loader 14066 Troy Bilt GTX/Duratrac
loader fel gtx duratrac 14066
21 replies to this topic
#16 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 245 Thanks
  • 130 posts
Posted February 24, 2017 - 07:29 PM
Thank you for the help. I had a couple of last questions. On my Troy Bilt there is a power steering cylinder on the left side (from the drivers seat). How did you mount around that? Did you go from the inside up and use nothing on the outside? Is that the 4th picture down? Any pictures would be great. Thank you.
#17 Cvans OFFLINE
  • 9635 Thanks
  • 7328 posts
Posted February 24, 2017 - 10:54 PM
I'll put a note up and try and get something for you tomorrow.
#18 Cvans OFFLINE
  • 9635 Thanks
  • 7328 posts
Posted February 25, 2017 - 01:38 PM
Here are some photos. Unfortunately It is hard to get photos that show much. I did remove the cylinder mount while installing this. Then I think I spaced the mount out from the frame to allow room for the loader mount. Please excuse the dirt as the pressure washer is put away for the winter.
This is looking straight down at the mount. It is between the cylinder mount and the hydraulic tube.
This is just to show that the cylinder mount has been spaced a small distance away from the frame.
This is looking up from the front toward the loader mount.
And from the rear at the same mount.
  • holdenboy1960 and mmmmmdonuts have said thanks
#19 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 245 Thanks
  • 130 posts
Posted February 25, 2017 - 03:07 PM
Thank you for the pictures. That helps tremendously. You haven't experienced a problem with having the cylinder spaced out a little with the steering? I was planning on using a 3 inch wide piece of angle and try and bolt it into two places. I guess I will have to try and see how it fits. Thank you.
  • Cvans and holdenboy1960 have said thanks
#20 Cvans OFFLINE
  • 9635 Thanks
  • 7328 posts
Posted February 25, 2017 - 03:57 PM
No problems at all. Wouldn't have thought about it if it wasn't for taking the photos. Looks like a couple of thick washers were used.
#21 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 245 Thanks
  • 130 posts
Posted February 26, 2017 - 06:32 PM
I appreciate it. I got most of the parts I need to start to build a loader. Just missing the hydraulic hoses, the pump and a little bit of tge It is the subframe mounting that I was having the most initial trouble with. I am probably going to start a new thread with the build progress I am making on the loader. Just waiting for better whether to really get started mounting everything.
#22 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 245 Thanks
  • 130 posts
Posted June 16, 2017 - 08:53 AM
I started a loader build thread located her: http://gardentractor...x-loader-build/
Also tagged with one or more of these keywords: loader, fel, gtx, duratrac, 14066
