TerraGrip Rubber Chains
13 replies to this topic
#1 RustyB ONLINE
RustyB
  • 190 Thanks
  • 94 posts
Posted December 14, 2016 - 08:27 PM
I need a little help. I have a new JD X580 GT with a snow blower on it...I bought a set of the rubber flat chains for it. The ride is so rough that it makes it unusable. I have wheel weights and 4 suit case weights Around 250 extra pounds of weight on it. I am running the original  Carlisle HD Field Trax tires on it. I have used GT's for over 25 years with steal chains and have never had a tractor ride this rough...like it is on a cobble stone street. It bounces so much it shakes the suit case weights up and down, then the tractor spins and hood shakes. That is at a slow speed.
Has anyone run into this? Any ideas on a fix? Tires? These tires are completely new to me. To much air? Running 12 lbs. Trying to save driveway.
Superior Tech - the company I bought them from has no idea - except the tire are not flat across the tread so the rubber bar is not making complete contact with pavement, They have offered to take them back. Sorry so long winded. Pics attached
Rusty
  • hamman, old coot and propane1 have said thanks
#2 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted December 14, 2016 - 08:30 PM
Been using these rubber chains since 2011 and have to say they are alot smoother a ride than Steel chains!
  • old coot and RustyB have said thanks
#3 Cvans ONLINE
  • 7,298 Thanks
  • 6,384 posts
Posted December 14, 2016 - 08:49 PM
Drop your rear air pressure down to 6 lbs. Your tires are stiffer in the cold and your not carrying much weight on the back with the blower hanging out front.
  • Alc, old coot and RustyB have said thanks
#4 RustyB ONLINE
RustyB
  • 190 Thanks
  • 94 posts
Posted December 14, 2016 - 09:07 PM
Thanks Tractorholic I hope that takes care of it. I was leaning towards replacing the tires with a extra set of turf tires that I think are the same size. Even the JD dealer told me to run 12 lbs of air even in the winter in those tires.
  • old coot said thank you
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted December 14, 2016 - 09:09 PM
Yep, what Chris said. Drop the pressure until they have some 'give' to them.
  • Cvans, old coot and RustyB have said thanks
#6 propane1 ONLINE
propane1
  • 9,470 Thanks
  • 4,397 posts
Posted December 14, 2016 - 09:12 PM
If they were 2 link instead of 4 link, the ride would be better. To much gap in between the cross bars on the 4 link ones.
Noel
  • Cvans, HANKG, old coot and 2 others have said thanks
#7 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted December 14, 2016 - 09:24 PM
  I agree, drop the pressure, I only run just enough pressure to get the tire up and that's it.  maybe 5lbs max.  Nice looking rig by the way.
        Pete
#8 RustyB ONLINE
RustyB
  • 190 Thanks
  • 94 posts
Posted December 14, 2016 - 09:34 PM
Thanks petrj6 First brand new tractor for me. Imagine this went to look at a used tractor, took the wife with and she thought we should buy new when she saw the shiny paint in the showroom. I still like working on the older ones I have though.
  • Cvans, TomLGT195 and old coot have said thanks
#9 shorty ONLINE
shorty
  • 5,836 Thanks
  • 5,417 posts
Posted December 15, 2016 - 06:52 AM
If dropping the pressure doesn't smooth out the ride enough. A set of two link where it has a cross strap twice as often gives a much smoother ride. My experience with the 4 link was not the best. Especially running the road to the neighbors.
  • RustyB said thank you
#10 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted December 15, 2016 - 09:39 AM
The snow will give you a cushion so you don't feel the bump of the rubber chains.
  • UncleWillie, propane1, RustyB and 1 other said thanks
#11 UncleWillie ONLINE
  • 16,257 Thanks
  • 8,975 posts
Posted December 15, 2016 - 03:56 PM
Exactly what I was going to say.
#12 RustyB ONLINE
RustyB
  • 190 Thanks
  • 94 posts
Posted December 15, 2016 - 06:11 PM
Thank you to all that responded. I had to much air in my tires...instructions said to go by the tire. lowered air pressure to 7.5 lbs, made the ride really smooth. Thanks again
  • Cvans and Cat385B have said thanks
#13 Cvans ONLINE
  • 7,298 Thanks
  • 6,384 posts
Posted December 15, 2016 - 06:34 PM
Glad your happy with the results   :thumbs:
#14 mtoney OFFLINE
mtoney
  • 830 Thanks
  • 693 posts
Posted December 22, 2016 - 02:42 PM
Any chains, be they metal(rougher than rubber on dry pavement)or rubber will give a rough ride on dry hard pavement.  Even 2 link will still be choppy feeling on the dry pavement.  But once in the snow, they go to work.  I run the rubber 4 link as you have with excellent traction and no damage to the driveway when I slip out.  Usually trying to back up the inclined drive with the snowblower off the ground will result in some slippage if I get to aggressive with the reverse peddle.  This is one reason its nice to have a second tractor that doesn't have chains on it for chore duties when the ground is dry.  The ride is much smoother!   Chains are going on the GT275 in about 30 min after I eat a late lunch.    Mike
Edited by mtoney, December 22, 2016 - 02:43 PM.
  • Cvans said thank you
