Starter/generator issue.
5 replies to this topic
#1 CraftsmanGT OFFLINE
CraftsmanGT
  • 368 Thanks
  • 321 posts
Posted December 14, 2016 - 11:56 AM
The starter/generator on my Bolens 1000 won't spin the engine over after a cold snap we've had here. The battery is fully charged but it just hums when I push the button. If I take the belt off it spins fine but as soon as any resistance is put on the pulley it stops and hums. It starts easy with the rope.
  • chieffan said thank you
#2 tater195 OFFLINE
tater195
  • 2347 Thanks
  • 1492 posts
Posted December 14, 2016 - 12:10 PM
Clean the connections at the battery, starter, ground and solenoid, then bypass the solenoid and see if it spins faster. Colder temps will tighten up the engine and will strain the starting components. it could be a weak battery or a starter issue, or just a high resistance connection somewhere.
  • Bolens 1000, nyrobbie77, boyscout862 and 2 others have said thanks
#3 chieffan ONLINE
  • 15497 Thanks
  • 8821 posts
Posted December 14, 2016 - 03:29 PM
A battery that worked fine in warm weather my not be enough in the cold like we been having.  The CCA has to be there to turn a cold engine over.  After checking what Tater195 mentioned and it still won't turn over you might put some heat on the engine.  I use a forced air Kerosene heater for about 20 min on mine.  Makes a world of difference.  If that don't do it then the bushings/bearings in the starter/generator may be bad.  Nothing worse than a motor that won't start when you need it.  Good luck.
  • boyscout862 and CraftsmanGT have said thanks
#4 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted December 14, 2016 - 04:04 PM
If the above are all ok, try Bearings, brushes, and commutator cleanup.
#5 Bolens 1000 ONLINE
  • 17309 Thanks
  • 18799 posts
Posted December 14, 2016 - 04:37 PM
Check your connections
Also what CCA is your battery these need about 300CCA or above to work right
  • MH81, WrenchinOnIt and CraftsmanGT have said thanks
#6 CraftsmanGT OFFLINE
CraftsmanGT
  • 368 Thanks
  • 321 posts
Posted December 15, 2016 - 05:26 PM
Got it figured out, the battery was bad even though it's only a year old. I swapped in the battery from my Allis 611 and it spun right over.
