It would come as a surprise if they weren't.
Bolens 5020H Duratrac GTX U-joint
#16
ONLINE
Posted June 03, 2017 - 09:37 PM
- Zekkjacen said thank you
#17
OFFLINE
Posted July 25, 2017 - 12:38 AM
Ended up putting it back together. Didn't drill anything out. Figured if it lasted 30yrs before, hopefully I can get another 20 with these bearings and I can always replace them again.
This series of pictures are deceptive if viewed just separately from the other pictures I posted. The caps all came off and all the pins were pressed out, etc.
Edited by Zekkjacen, July 25, 2017 - 03:42 AM.
- Alc and kg5000 have said thanks
#18
OFFLINE
Posted July 25, 2017 - 12:47 AM
It would be really nice if you posted some step-by-step pics and part numbers of your u-joint rebuilding. Tons of us out here have the same problem. Paul
Think I should add anything else?
#19
OFFLINE
Posted July 25, 2017 - 02:50 AM
So the first 3 photos are of the old and the 4th is the finished product with new bearings? How did that go together? Just pressed in and stays put?
#20
OFFLINE
Posted July 25, 2017 - 02:51 AM
correct.
- Paulgo and kg5000 have said thanks
#21
OFFLINE
Gotta pull the caps, press the pins out, press the raceway out, clean it up, grease, press the new bearings in.
