Bolens 5020H Duratrac GTX U-joint
20 replies to this topic
#1 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted December 11, 2016 - 08:13 AM
So,  need some help.  I have a spare that I am using right now, but I had the U-joint go out on my drive with the locking ring has gone out on me.  Anyone have experience replacing these?  Or where I can buy a replacement U-joint?
I could go to Napa and find a U-joint to match up, But I would also like to give business to anyone who helps support this hobby.
#2 boyscout862 ONLINE
  • 15259 Thanks
  • 10022 posts
Posted December 11, 2016 - 09:46 AM
Check with our sponsors on the top of the Forums page. Atleast 2 of them specialize in Bolens. You will find that they are often cheaper than other parts suppliers. Good Luck, Rick
Edited by boyscout862, December 11, 2016 - 09:48 AM.
#3 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted December 11, 2016 - 11:33 AM
Betcha a Grain Belt Nordeast that Rick has one: http://gardentractor...ckjackjakexxix/
#4 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted December 11, 2016 - 11:38 AM
I believe I just need a U-joint and not the entire assembly.
#5 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted December 11, 2016 - 03:13 PM
I believe I have a good used one if your interested
Edited by blackjackjakexxix, December 11, 2016 - 03:14 PM.
  • Zekkjacen said thank you
#6 Cvans OFFLINE
  • 9624 Thanks
  • 7317 posts
Posted December 11, 2016 - 03:44 PM
If rick doesn't have one for you I'm just about positive I do.
#7 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted April 14, 2017 - 07:02 AM
So I started tearing into that u-joint... one of those non-rebuildable types. I have access to Mills and Lathes... let me know what you want for for one of those couplers
#8 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted April 14, 2017 - 07:33 AM
Sorry sold the last one I had,Rick
#9 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted April 16, 2017 - 06:57 AM
Is that the same yoke, and joint as the the older Bolens stuff? Here are a couple links for the Weasler 6 series.
Measure the bearing cap diameters, and cross section to be sure of what you have.
http://www.paulbpart...before-shipping
https://www.farmandf...CFV64wAodI30CiQ
Edited by stiemmy, April 16, 2017 - 06:59 AM.
  • Zekkjacen and Paulgo have said thanks
#10 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22734 Thanks
  • 7514 posts
Posted April 16, 2017 - 07:17 AM
If it is a 1"-15 spline these 1900 series Precision U Joint catalog pages may be helpful as they show a 1"-15 spline locking collar yoke and a slip yoke.
  • KennyP, Zekkjacen and Paulgo have said thanks
#11 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted May 28, 2017 - 08:04 PM
So, I did end up making a universal joint.  It cost me more than I originally expected, but wasn't awful.  I had about $90 in it. I ordered the parts through NAPA @ about $35ea, then they charged $10 shipping for each one.  This didn't include a U-joint, so add $10-12 if you are planning on it.
I used a 2-bolt clamp down style rather than the quick connect, as the 2000 Eliminator used the locking collar style.  the other end is the 3/4 x 7/8 shaft opening.
I have 3 of the locking collar u-joints.  I am rebuilding them with new end-cap bearings, as these are non replaceable u-joints.  I'll have $20 in rebuilding each of them.
#12 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted May 30, 2017 - 10:13 AM
It would be really nice if you posted some step-by-step pics and part numbers of your u-joint rebuilding. Tons of us out here have the same problem.  Paul
  • Cvans and Zekkjacen have said thanks
#13 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted May 30, 2017 - 10:52 PM
I plan to.  Just not there yet. somewheres around GTtalk I posted the bearings I am using... Koyo
  • Cvans said thank you
#14 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted May 31, 2017 - 12:30 AM
Okay,  so here is what I have so far.  This weekend I hope to have more.
Parts: Koyo M-661  I’ve Purchased on both ebay and amazon. http://www.ebay.com/...=STRK:MEBIDX:IT
Remove Caps (additional pics later.  Easy enough to figure out).  Screwdriver and hammer.  Puncture, insert, pry out.
Once caps are removed from either side, take a punch and tap out the pins straight through to remove. Don’t damage the pins (yes, I’m sure everyone understands that, but you never know who will be reading this in 5 years).
Clean up the openings for the new bearings.
You could grease the bearings as they are and put it back together and hopefully it will last you another 20-30 years…. But I will chuck these pins up in a lathe and drill a hole through each pin.  I’ll also drill and tap the block for a grease fitting.
Edited by Zekkjacen, May 31, 2017 - 12:32 AM.
  • Cvans and Paulgo have said thanks
#15 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted June 03, 2017 - 02:36 AM
Ain't happen'n this weekend...
Also,  does anyone know offhand if these pins would be hardened?  I haven't tested them yet.
