Add extra switch panel.
10 replies to this topic
#1 c.wiklund OFFLINE
c.wiklund
  • 50 Thanks
  • 38 posts
Posted December 10, 2016 - 11:45 AM
Hi!
I want a few extra switches horns and plow lamp. Is there something smart to buy that is waterproof. Something like this: DF_SP33_1.jpg
I do not have much space on the dashboard, so I have probably put an extra panel elsewhere
or replace the light switch to a 3 way rotary switch
Edited by c.wiklund, December 10, 2016 - 11:58 AM.
#2 shorty ONLINE
shorty
  • 5,507 Thanks
  • 5,271 posts
Posted December 10, 2016 - 12:02 PM
I have used regular toggle switches for adding extra circuit. Some have a rubber boot for weather resistance.
  • MH81, boyscout862, old coot and 1 other said thanks
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted December 10, 2016 - 12:11 PM
Is that an empty hole next to the hour meter?
If so, you could fab up a little plate to go over that, toss in a couple of waterproof toggles, and be good to go.
  • boyscout862, old coot and c.wiklund have said thanks
#4 c.wiklund OFFLINE
c.wiklund
  • 50 Thanks
  • 38 posts
Posted December 10, 2016 - 12:12 PM
 Hi shorty! Yes I also looked at the type..
But one of the problems is that there are no good places to put switch. I will kick them or get caught in them. So you would have a panel where they are a little recessed.
Stiemmy Yes it's a empty hole but I plan to add a fuel gauge.
Edited by c.wiklund, December 10, 2016 - 12:13 PM.
  • shorty and old coot have said thanks
#5 c.wiklund OFFLINE
c.wiklund
  • 50 Thanks
  • 38 posts
Posted December 10, 2016 - 12:26 PM
I wonder if I would put a panel next to the key
or next to the chair
  • old coot said thank you
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted December 10, 2016 - 01:03 PM
Next to the key maybe a good option.
  • shorty and c.wiklund have said thanks
#7 MiCarl ONLINE
MiCarl
  • 2,057 Thanks
  • 1,058 posts
Posted December 10, 2016 - 01:35 PM
We just completely refitted out pontoon boat.
I ordered a custom panel from these folks: https://newwiremarine.com/
Haven't used it yet but it seems to be well built.  They sell individual switches if you want to build them in to your own panel.
  • old coot and c.wiklund have said thanks
#8 boyscout862 ONLINE
  • 12,871 Thanks
  • 9,180 posts
Posted December 10, 2016 - 01:36 PM
Be carefull that you don't overload the charging system. Good Luck, Rick
#9 c.wiklund OFFLINE
c.wiklund
  • 50 Thanks
  • 38 posts
Posted December 10, 2016 - 01:41 PM
Hi Micarl! Thanks! I will check that.
I also found this, but I wonder if it is weather resistant.
I could replace the switch on the panel.
http://en.laboutique...avid-brown.aspx
I plan to switch all the lights to LED in place of the old ones, so I hope I shall reduce the load
Edited by c.wiklund, December 10, 2016 - 01:46 PM.
  • boyscout862, TomLGT195 and old coot have said thanks
#10 MH81 OFFLINE
Posted December 10, 2016 - 10:48 PM
If these are winter use only or something you won't need all the time, you may want to consider a pig-tail and a magnetic anchored box on the hood.
You could remove the box and tuck the wires away when not needed.
#11 c.wiklund OFFLINE
c.wiklund
  • 50 Thanks
  • 38 posts
Posted December 11, 2016 - 04:15 AM
Hi MH81! Yes it is a smart solution.
But I live att 59Latitude so we have "winter" ½ year.. :-)  Well not winter, but dark.
But someting like this culd be smart
Edited by c.wiklund, December 11, 2016 - 04:19 AM.
  • MH81, boyscout862 and old coot have said thanks
