Implements for AC410
8 replies to this topic
#1 Allis410 OFFLINE
Allis410
  • 1 posts
Posted June 01, 2011 - 10:15 PM
Where can I find a list of implements that were made for the Allis Chalmers 410? I'm particularly interested in a sickle bar. Thanks in advance !
#2 MH81 ONLINE
  • 28,390 Thanks
  • 29,104 posts
Posted June 01, 2011 - 10:21 PM
I don't see a sickle bar for them as a AC unit. Haban probably made one that fit tho
here's a partial list of the 400 series attachments. 400 series attachments
  • Texas Deere and Horse and Allis410 have said thanks
  • 14,468 Thanks
  • 15,392 posts
Posted June 01, 2011 - 10:22 PM
Here's what I could find for you...
Mowers feature an overlapping blade design for smooth, uniform cut without scalping. Blades lift grass and discharge uniformly.
Attach a vacuum collector and your lawn comes clean. . . picks up leaves and clippings for that professional look.
Lawn revitalizer is a combination dethatcher-aerator. . . brings lawn-choking thatch to the surface and cuts grooves in soil for air and water.
Turn your 400 series tractor into an earth and snow mover with a dozer blade. . . saves hours of shovel work.
Big 36"rotary tiller digs to 7" to break and blend the soil for seedbeds that plant easier, produce healthy results.
Here’s a light weight dump cart for a multitude of hauling chores. . . makes lawn and garden care easier.
  • kwj427 and Allis410 have said thanks
  • 14,468 Thanks
  • 15,392 posts
Posted June 01, 2011 - 10:23 PM
Alan, you beat me to it..
#5 MH81 ONLINE
  • 28,390 Thanks
  • 29,104 posts
Posted June 01, 2011 - 10:25 PM
yeah, but you put in more effort. LOL, I just gave a link
#6 Texas Deere and Horse OFFLINE
  • 14,468 Thanks
  • 15,392 posts
Posted June 01, 2011 - 10:31 PM
I just love them pictures..:yelclap:
  • 14,468 Thanks
  • 15,392 posts
Posted June 01, 2011 - 10:40 PM
Here is the list of attachments for the 1973 Landlord 10Hp. I believe that it is the same tractor as the A/C 410
Hope this helps...
Landlord®, the number two Simplicity, with two drive options to choose from. 4-speed Shuttling Drive provides instant reversing in any of the four speed ranges... without clutching. Pull shuttle lever toward reverse to slow or stop the tractor... all the way back to reverse tractor. 3-speed standard gear drive is rugged ... works smooth and easy, transmits full power of the 10 hp. engine. Both Shuttle Drive and Touch-O-Matic clutch can be feathered to slow tractor without shifting. Ideal for mowing around trees and shrubs where careful control is necessary. Optional electric powerlift lets you raise, lower and hold attachments in position with the touch of a lever. Standard electric start gets you going fast. 42" mower keeps the cutting fast... up to 2 acres per hour. Front (furnished with snow thrower) ... or center and rear power takeoffs are controlled independently of engine drive.
42" Rotary Mower.
46" Sickle Bar Mower.
Vacuum Collector and Roving Nozzle.
Dump Cart.
38" Lawn Revitalizer.
36" Snow Thrower.
42" and 46" Snow Plow and Dozer Blade.
Hard Top Snow Cab.
36" Tiller and Tine Extensions.
10" Moldboard Plow.
Cultivator.
Spring Tooth Harrow.
42" Grader Blade.
Rear Ball Hitch.
Front Dual Lights.
Rear Flood Light.
Hubcaps.
Front and Rear Wheel Weights.
Front Weight.
Electric Powerlift.
Tire Chains.
Hour Meter.
  • MH81 and Allis410 have said thanks
#8 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted August 10, 2011 - 11:25 AM
I am pretty sure that Simplicity did not make the 300 or 400 series for Allis-Chalmers. I believe that Allis-Chalmers produced them themselves.
#9 acguy96 OFFLINE
acguy96
  • 26 Thanks
  • 44 posts
Posted August 10, 2011 - 11:50 AM
According to my 400 Series Parts Catalog, there was a
46" Dozer Blade,
42” Grader Blade,
42” Snow Plow & Dozer,
Cab for Electric Lift,
Cab for Manual Lift,
Composter,
Vacuum Collector,
Low Profile Vacuum Collector,
Dump Cart,
Roving Nozzle for the Vacuum Collector,
Row Crop Cultivator,
Spring Tooth Harrow,
42” Rotary Mower,
48” Rotary Mower,
Sickle Bare Mower,
10” Plow,
Snow Thrower,
Lawn Sweeper,
Revitalizer,
and a 36” Rotary Tiller.
[FONT="]Hope this helps![/FONT]
