Splined tube/yoke repair
17 replies to this topic
#16 SimplyRad OFFLINE
SimplyRad
  • 1,020 Thanks
  • 786 posts
Posted December 08, 2016 - 08:42 AM
29 Chev
I liked your tool for putting the splines in the coupler. When I put a keyway in small couplers I just cranked the slide.
  • 29 Chev said thank you
#17 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,065 Thanks
  • 2,661 posts
Posted December 08, 2016 - 02:28 PM
29 Chev
On a little 6" lathe the small wheel is hard to turn and puts a bit of stress on the carriage gears - the handle set up is fairly simple and gives more leverage so it is not nearly as fatiguing on repetitive passes.
  • SimplyRad said thank you
#18 SimplyRad OFFLINE
SimplyRad
  • 1,020 Thanks
  • 786 posts
Posted December 09, 2016 - 08:58 AM
The lathes I operated were at least 16" or bigger. One lathe I operated when I was a production machinist would swing 75" x 30'.
  • michael.kitko said thank you
