MTD Wheel Weights
5 replies to this topic
#1 lyall ONLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted December 03, 2016 - 05:57 PM
I got a used set of MTD tractor wheel weights OEM-190-784
This are 50 lbs. each.
Tried to put them on a set  JD wheels (tire size 23x10.5x12)
They will not fit on the rims, just a little to big to fit.
They are are 12" rims.
Why won't they fit?
They look good and fill good, the plastic is not cracked or broken.
No noise from the inside of the wheel weights.  I do not want to force them on.
Any idea why?
thanks
#2 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted December 03, 2016 - 06:17 PM
JD wheels made with thicker metal?
#3 boyscout862 OFFLINE
  • 12,534 Thanks
  • 9,034 posts
Posted December 03, 2016 - 07:15 PM
My MTD wheels are four lug. My JD wheels are five lug(as are most). Maybe there is a difference in the inner diameter. Don't force anything or they will just break. Good Luck, Rick
  • lyall said thank you
#4 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,112 Thanks
  • 4,883 posts
Posted December 03, 2016 - 07:18 PM
Deere's rim must have a deeper "drop center"   ???
#5 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted December 03, 2016 - 07:22 PM
That's odd, as I've used the same weights on my John Deere F935.
#6 EricFromPa ONLINE
EricFromPa
  • 3,514 Thanks
  • 3,066 posts
Posted December 03, 2016 - 09:53 PM
I have a set of rear rims off of a Craftsman 2 GT5000 and 2 sets of rims off of old Cub Cadet tractors.The center of the Craftsman rims ARE slightly wider.Wider by 1/8" maybe a little bit more.My 2 30lb sets of cast iron walk behind tractor weights won't fit the Cub Cadet rims but fit the craftsman rims just fine.Still a little tight but these weights were made for the old 4x12 rims with 5x12 tires.
Edited by EricFromPa, December 03, 2016 - 09:58 PM.
