Maybe something here that would work?
I am sure that I can find something from them. A gr 5 will be better that the local hardware.
Posted January 09, 2017 - 07:44 AM
The harrows look great. Keep up the great work this is one nice project.
Posted January 13, 2017 - 03:16 PM
The harrows cleaned up very nicely. Each set was totally disassembled and sand blasted. Then each component was wiped down with solvent and primed then painted. I only had to replace 3 bolts. Only one more attachment to do and the will be that plow blade. I plan on starting that tomorrow.
Edited by Deerlope, January 13, 2017 - 03:19 PM.
Posted January 14, 2017 - 02:21 PM
Well I got it in the garage today does anyone have any information on it. The tag on it says Bolens R 502A01. It measures 48" wide and is mostly aluminum. The Alu measures 18Ga or close to it, and it all needs to be replaced. Someone has done a poor job of trying to repair it with fiberglass.
Posted January 14, 2017 - 03:46 PM
That is the snow blade for these what info you need?
Posted January 14, 2017 - 08:22 PM
Does the lifting cable hook into the attachment lifting lever?
Posted January 18, 2017 - 04:14 PM
This is about the best repair I could make on the snow plow blade. The Alu was harder to work with than I had thought it would be. I know that as crude of a job that I did on it will plow and/or roll the snow. Now all I need is to get my engine back from the shop and the unit is all done.
Posted January 19, 2017 - 12:27 PM
Considering what it started out as I think that you did a fine job on the plow. It will be a heavy duty attachment that you won't have to worry about breaking.
Posted January 19, 2017 - 05:37 PM
I was told by a few when I got this Ridemaster that this was not the right air cleaner assemble for it. The correct on supposedly comes off the same but right turns towards the rope pulley . Anyone got a pic of an AKS with correct air cleaner assemble on it.
Posted January 19, 2017 - 05:58 PM
Wilberj, was the above setup on mine used on all Ridemasters with the Wisconsin?
Posted January 19, 2017 - 06:12 PM
Yours above would have been correct for that engine if it came as a stationary engine or on another application, the one Bolens used was special
Here's the Bolens setup
That is the set up that I have and I would like to know how it is supported other than that bolt style clamp where it goes on the carb.
Edited by Deerlope, January 19, 2017 - 06:12 PM.
Posted January 19, 2017 - 07:12 PM
The clamp is the only support
Posted January 19, 2017 - 07:21 PM
The metal bracket...
Posted January 19, 2017 - 07:51 PM
I don't see no metal bracket other than a brace back to a bolt that goes into the mag. I guess I can make something that will work.
