316 Battery Light
5 replies to this topic
#1 WestMichigan OFFLINE
WestMichigan
  • 2 posts
Posted June 01, 2011 - 01:46 PM
My tractor seems to be eating batteries for lunch. The battery light is intermittently on when running. It seems to be on more often when I have the PTO engaged and am mowing grass. It also seems to be off when I first start up the tractor and the longer I run the more likely it is to be on. I bought the tractor used last fall and have only mowed once so far this year, but I also plowed some snow with it over the winter. When I put a meter on the battery with the PTO off and the tractor idling I read 13.8V so it seems to be charging the battery at least part of the time.
#2 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted June 01, 2011 - 02:26 PM
What kind of voltage is it reading with the pto off and tractor at high idle or mid throttle? I am wondering if the battery light is coming on because it is overcharging? I would expect to see 13.8 volts at mid to high throttle.
#3 WestMichigan OFFLINE
WestMichigan
  • 2 posts
Posted June 01, 2011 - 02:30 PM
I have kid duty tonight so I don't know if I will get to check it, but the next time I have it on I will check the voltage with PTO on/off and at low/high throttle and see if there is any difference.
#4 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted June 01, 2011 - 02:46 PM
Could just be a bad light/sensor or it seems like it might be overcharging. I would definitely get some more readings with the multimeter and let us know what you find out.
  • 14,862 Thanks
  • 15,511 posts
Posted June 01, 2011 - 06:06 PM
Which 316 do you have, Series 1 with a K-341 Kohler, or Series 2 with an Onan?
#6 tm140 OFFLINE
tm140
  • 1 Thanks
  • 14 posts
Posted June 11, 2011 - 08:38 AM
Sounds like the voltage regulator is bad
