Front end loader jib boom
11 replies to this topic
#1 Alc ONLINE
  • 6,610 Thanks
  • 7,339 posts
Posted November 28, 2016 - 08:00 PM
I wasn't sure to build a jib boom for the PKs 3 point but decided on one to attach to the bucket. It just slips on the bucket lip then chained to a hook welded to the bucket.
Edited by Alc, November 28, 2016 - 08:02 PM.
  • Gtractor, MH81, Bruce Dorsi and 10 others have said thanks
#2 shorty ONLINE
shorty
  • 4,985 Thanks
  • 5,036 posts
Posted November 28, 2016 - 08:07 PM
Really gets it up and out there. Neat idea.
#3 Alc ONLINE
  • 6,610 Thanks
  • 7,339 posts
Posted November 28, 2016 - 08:09 PM
Just the way pictured it should work good to about 150 lb anything more I will chain the bucket to the crossmember on the loader frame . The bucket tilt cylinders don't have enough power to move the boom once there's a load at all so I wouldnt trust them without an extra chain. In fact if you would try to curl the bucket back it would tilt forward , no load checks in the loader valve .
  • Gtractor, Cvans and MFDAC have said thanks
#4 boyscout862 ONLINE
  • 12,192 Thanks
  • 8,901 posts
Posted November 28, 2016 - 08:13 PM
Nice. It is always good to find more ways to use our toys.
I did a similar setup for my shoveldozer 25 years ago but never got to use it.  We were taught a similar field expediant in the Army, 40 years ago. We used the front of a 5 ton bridge truck, two pipe braces and the front winch. Good Luck, Rick
#5 Austen ONLINE
Austen
  • 1,476 Thanks
  • 850 posts
Posted November 28, 2016 - 09:14 PM
Nice setup! Loaders look good on PKs.
#6 gt-14 OFFLINE
gt-14
  • 4 Thanks
  • 23 posts
Posted November 28, 2016 - 10:38 PM
I think tractor guys can come up with the best ideas to make the work easier great job
#7 KennyP ONLINE
  • 36,532 Thanks
  • 44,982 posts
Posted November 29, 2016 - 05:49 AM
Neat attachment! Think I would have went a little shorter though.
#8 Alc ONLINE
  • 6,610 Thanks
  • 7,339 posts
Posted November 29, 2016 - 06:28 AM
I  wanted it long enough to pull plants from the little pond you see in the background , at the end of the season they grow so big I can't lift them without my son helping , this way I can get them myself . I wasn't sure if I could reach but after I took those pictures of the plow I lowered it over a small retaining wall and shrubs to the front of the garage . I used to have to lift it with the hook on the bucket and drive out into the street from my lower driveway to upper .   No shoulder , blind spots , too much traffic anymore . It would  be nice to be able to tilt the bucket with a load , maybe mounting a HF winch on the loader crossmember to take some of the weight off the bucket tilt cylinders ?
#9 KennyP ONLINE
  • 36,532 Thanks
  • 44,982 posts
Posted November 29, 2016 - 06:53 AM
That explains the length!
#10 Alc ONLINE
  • 6,610 Thanks
  • 7,339 posts
Posted November 29, 2016 - 08:38 AM
I wonder if I welded another set of tabs on the bucket for the rod ends of the bucket tilt cylinders  they would have enough leverage  to tilt with a load ?  Those cylinders are meant to be moved easily , when I put the snow plow one gets locked solid to the  plow frame and the other becomes the snow plow angle cylinder
#11 KennyP ONLINE
  • 36,532 Thanks
  • 44,982 posts
Posted November 29, 2016 - 09:17 AM
That's a geometry problem and I have forgotten all of that! I am having that issue on Alice's 3-point and plan to move the cylinder pin further from the pivot some to see if it helps it lift more weight with less pressure. That might work for you when using the pole!
#12 Alc ONLINE
  • 6,610 Thanks
  • 7,339 posts
Posted November 30, 2016 - 06:31 AM
I looked at the bucket last night and welding another set of tabs for the tilt cylinders will be worth a try . I made clamp-on forks for years ago  it but had the same problem that you  couldn't adjust the level once there was a load on it. I'll have to play around with placement , I'll do the same as the factory did by welding squares flat  against  the bucket , then the tabs to them
