Fuel filter/check valve
2 replies to this topic
#1 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted June 01, 2011 - 08:07 AM
If I remove the reserve line from the 318 to see what happened to it ( see other post ) I was thinking that on my son's old Ski-Doo snowmobile there was a in tank filter on the fuel line that had a built-in check valve . That might keep the fuel in the line from draining back after sitting and making it take so long to start . Would just put it on the ON line and not the reserve . I saw some added electric fuel pumps to fix this problem too. Any thoughts on this ?
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted June 01, 2011 - 11:36 AM
Want to watch pressures on the electric add-ons. I think <5 psi is where you'd want to be? :anyone:
#3 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted June 06, 2011 - 09:25 PM
I found these fuel filers /check valve , I think it would help with the starting problem , should keep the fuel from draining back into the tank.
http://www.outdoorsu...gifunction=form
