How to Pull a Fence Post . . .
12 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,634 Thanks
  • 9,444 posts
Posted November 24, 2016 - 08:21 AM
with a spare tire.  http://www.alloutdoo...ve-fence-posts/
  • ducky, jms180, hamman and 5 others have said thanks
#2 shorty ONLINE
shorty
  • 4,979 Thanks
  • 5,035 posts
Posted November 24, 2016 - 08:25 AM
Great way to use what is on hand. And now he has a post hole to sell.😄
  • hamman and KennyP have said thanks
#3 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted November 24, 2016 - 09:06 AM
Old trick, used to just be the tractor tire and a chain. Lots of guys got hurt that way.
I can see several injuries here too. Guy is straddling the post (Darwin award nominee?) And also, the tire is tipping. Lots of stored energy when it goes sproing.
Takes a good driver too, not Bubba "HoldMaBeer" Jones from the bar
  • ducky, chris m, boyscout862 and 3 others have said thanks
#4 KC9KAS OFFLINE
KC9KAS
  • 5,267 Thanks
  • 4,643 posts
Posted November 24, 2016 - 09:19 AM
I have used just the wheel...no tire....chain stays in place better.
I also have added a "Vise-Grip" to keep the chain from slipping up...(usually on a steel post)
  • boyscout862 and oldedeeres have said thanks
#5 toppop52 ONLINE
toppop52
  • 4,905 Thanks
  • 4,559 posts
Posted November 24, 2016 - 09:24 AM
Dibs! :D
  • shorty said thank you
#6 SimplyRad OFFLINE
SimplyRad
  • 984 Thanks
  • 759 posts
Posted November 24, 2016 - 11:08 AM
Never pulled a fence post but have used the basic idea to pull some small stumps using a 4 x 4 and chain.
Edited by SimplyRad, November 24, 2016 - 11:08 AM.
  • oldedeeres said thank you
#7 oldedeeres ONLINE
oldedeeres
  • 8,717 Thanks
  • 4,482 posts
Posted November 24, 2016 - 11:36 AM
Back in the day my father was a lineman for Ontario Hydro. As a child I learned by watching , he could change out a power pole by himself using much the same principle. This was long before "safety" became an issue. The job was there, you did it, or the company let you go. And we lived at least 100 air miles north of civilization; necessity is the mother of invention.
  • MH81, KennyP, chris m and 1 other said thanks
#8 Jazz OFFLINE
Jazz
  • 2,188 Thanks
  • 1,354 posts
Posted November 24, 2016 - 02:26 PM
Good idea but also notice those fence posts are barely in the ground. We sink ours 3' to 4' for frost as well as strength. I would try that method. I have always used my cherry picker.  Once the post breaks free of the binding ground or lifts a few inches you can lift them out by hand easily.
  • MH81 and oldedeeres have said thanks
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,757 Thanks
  • 4,301 posts
Posted November 24, 2016 - 03:42 PM
I just use a chain and hydraulic hi-lift jack. Much more control, and like said above, only need to lift it a couple inches then it will lift right out.
#10 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted November 24, 2016 - 08:19 PM
3 point hitch work pretty well too. The larger the tractor the bigger the post you can pull.
#11 karel ONLINE
karel
  • 1,922 Thanks
  • 1,296 posts
Posted November 25, 2016 - 08:11 AM
What happens when its set in cement?
#12 Cat385B ONLINE
    HAZMAT CAT
  • 13,525 Thanks
  • 9,821 posts
Posted November 25, 2016 - 08:21 AM
I just scoop them up and shake the dirt to get the post loose.
#13 SimplyRad OFFLINE
SimplyRad
  • 984 Thanks
  • 759 posts
Posted November 25, 2016 - 10:01 AM
I saw a fence company use a tripod with a hoist to pull steel posts set in concrete.
