Sold
Simplicity 10" sleeve hitch plow - $100
1 reply to this topic
#1 MiCarl ONLINE
MiCarl
  • 1,832 Thanks
  • 991 posts
Posted November 23, 2016 - 02:18 PM
I bought this plow to use for a plow day.  I did plow with it a bit.
Model 204 and part of model 203 hitch.  Manual indicates it works with 2 wheeled tractors, Model 725 tractor and Landlord tractor.
The hitch end of the beam was cracked and the standard and beam were slightly bent.  I welded the hitch end and straightened the beam and standard.  I also welded ears on the hitch end to limit swing with a standard sleeve hitch.  After I did all that I got a great deal on a 3pt. plow so don't need this one.
Of course what was left of the paint was ruined working on it.  It's been media blasted and painted.  I'm including the Simplicity sleeve hitch that I got with the plow.  It's also got the lift chain but not the lift arm portion.
The ears I welded on will not interfere with the Simplicity hitch.
The moldboard is on good condition and the share doesn't seem to have excessive wear.  I do not have the coulter.
As I reassembled I see the shoe might be bent just a bit but don't think that will be an issue.  I successfully plowed it with it more bent up than it is now.  I do not have the coulter.
Obviously the plow spent some time outdoors.  There is some pitting all over it.
It's in Plymouth, Michigan.  I will be traveling to the Akron, Ohio area over the holidays and could transport there or along the route.
Edited by MiCarl, November 24, 2016 - 12:36 PM.
#2 MiCarl ONLINE
MiCarl
  • 1,832 Thanks
  • 991 posts
Posted November 24, 2016 - 09:37 PM
Spoken for.
Also tagged with one or more of these keywords: Sold
