JD 265 manual implement lift issues
1 reply to this topic
#1 Jclayton OFFLINE
Jclayton
  • 1 posts
Posted November 22, 2016 - 10:23 AM
Hello all, I'm looking for assistance it troubleshooting why my manual lift isn't working- I think I might be missing something. To jog some memories the 265 has the manual lift lever on the right rear fender next to the hydrostatic drive lever.
Here's the issue- I just purchased the manual front implement lift kit for the snowblower attachment and I have to pull the lift lever with so much force that I'm afraid it will break. This can't be the way that this attachment is designed to work. Does anyone have any experience with this model and blower? Thanks in advance!
#2 boyscout862 OFFLINE
  • 12,858 Thanks
  • 9,173 posts
Posted November 22, 2016 - 02:05 PM
Welcome to GTT. We try to be helpfull. A member that has the same tractor as you may be along to help. If you post some clear pics, more people may be able to spot the problem. A snowblower is a heavy attachment, as you said. There may be a helper spring to make the lifting easier. It would be best to get the manual. JD does not let us post their manuals. Someone may be able to help you with that. Good Luck, Rick
