26's on a Duratrac/GTX20
12 replies to this topic
#1 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted November 21, 2016 - 11:34 PM
Anybody put 26's on there Duratrac/GTX20?  Any clearance problems?
Also, anybody know the bolt pattern of the rear wheels, ie,
or what might fit and what the off set should be?
I'm planning to put a larger dia ft tire on and would like to keep it level.
Dan
#2 ClassicBolens OFFLINE
ClassicBolens
  • 1525 Thanks
  • 516 posts
Posted November 22, 2016 - 09:58 AM
I believe WrenchinOnIt has 26x12-12 on his Duratrac with no clearance issues. Hopefully he'll chime in here with details.
  • WrenchinOnIt and DL-North have said thanks
#3 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted November 23, 2016 - 07:26 PM
Update
I found some discussion from WrenchinOnIt and he said they didn't fit,
and he has 25/24(something) x 12-12 on his Duratrac.
I also measured mine and it's 1 3/4 from the rubber to the bottom corner of the foot board, mighty tight with a 3" larger OD tire.
What to do??  I have a line on some 26's at a good price, but nowhere to put them. :(
Dan
  • KennyP and ClassicBolens have said thanks
#4 KennyP ONLINE
  • 50038 Thanks
  • 52259 posts
Posted November 24, 2016 - 10:10 AM
Update
Dan
What brand? They may be a bit small!
#5 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5017 Thanks
  • 1202 posts
Posted November 24, 2016 - 02:51 PM
Update
Dan
http://gardentractor...9l#entry680025. Pretty sure I tried the Goodyear Softrac's off the 1669L and there was zero clearance. I had to change the fronts from 16's to 18's on the 1669L to level it out, you'd be looking at the same thing I would guess when you increase rear circumference substantially.
Good point! Here's a link that will help visualize on the three most popular ag choices.
http://www.ebay.com/...=item2a6da07860
  • DL-North said thank you
#6 KennyP ONLINE
  • 50038 Thanks
  • 52259 posts
Posted November 24, 2016 - 03:47 PM
If I remember, I'll measure the BKT 26X12's on Alice. They are on 8.5" wide wheels.
#7 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted November 25, 2016 - 12:30 AM
Thanks Guys,
The 18's on the front, yes, that is what is driving it. I'd like larger tires up front and need larger in back to level out.
The plan was to put 18 x 6 x 8 on, same width, just larger OD.
Not sure the tire brand, plan to go look at them Fri, will likely buy then and keep my fingers crossed.
26 x 12's on a 8.5 rim, doesn't that bow them in a lot?  This seems to be my biggest problem, finding reasonably priced 26 x 12 rims.
And of course with the right off set.
Not planning ag treads, as this is likely a grass machine. I may do a little back blading but mainly mowing.
Dan
  • KennyP and WrenchinOnIt have said thanks
#8 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted November 25, 2016 - 06:14 AM
Unless you're going off-roading with it, I don't understand the attraction of larger than stock tires. There is no advantage to it.
#9 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted November 25, 2016 - 08:59 AM
Ya, I know, but I just don't like the little tires up front.
I do take it into the back yard to mow a patch in the woods, and there are some "rough" areas of the yard,
but it's mainly the bug up my bxxx about little tires.
Dan
  • WrenchinOnIt and Austen have said thanks
#10 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5017 Thanks
  • 1202 posts
Posted November 25, 2016 - 09:29 AM
I'll blame my affliction of the "biggest tire that will fit" on being a teenager in the late '70's , Jack um up with re-arched springs and air shocks, mount em up and cruise
I never got over it so now my GT's get the same...
  • LPBolens, blackjackjakexxix, Cvans and 3 others have said thanks
#11 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3618 Thanks
  • 2329 posts
Posted November 25, 2016 - 10:06 AM
Nice car,great body style
#12 Canawler OFFLINE
Canawler
  • 1953 Thanks
  • 1806 posts
Posted November 27, 2016 - 07:13 PM
I've got 25x10.50-12 Carlisle All-Trails on my GTX-18 with no clearance issues.
  • Cvans and DL-North have said thanks
#13 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted November 27, 2016 - 09:22 PM
Ya, 25's should be fine, 3/4" clearance if my numbers are any good.  That or 24's are likely what will end up on it.
