Transaxle ID?
7 replies to this topic
#1 DZG OFFLINE
DZG
  • 609 Thanks
  • 526 posts
Posted November 21, 2016 - 05:05 PM
Obviously its a peerless :D.
But its out of my lt8 ford, 5 speed, i cant find any model numbers on it, im guessing its common. I yanked it because the pully was loose and flopping around, i think the woodruff key is messed up, once the pullys off everything spins well and is tight.
Input?
#2 boyscout862 OFFLINE
  • 13,557 Thanks
  • 9,431 posts
Posted November 21, 2016 - 05:21 PM
There are some Peerless Manuals in our Manuals Section. Good Luck, Rick
#3 DZG OFFLINE
DZG
  • 609 Thanks
  • 526 posts
Posted November 21, 2016 - 05:32 PM
I cannot seem to find the manuals section :/
#4 KennyP OFFLINE
  • 40,974 Thanks
  • 47,143 posts
Posted November 22, 2016 - 08:07 AM
The Manual section is at the top, right next to the Forums tab. Just scroll to the top of the page and look toward the left side.
#5 KennyP OFFLINE
  • 40,974 Thanks
  • 47,143 posts
Posted November 22, 2016 - 08:23 AM
Did a little sleuthing and New Holland says this could be either an 801-020C, 920-012 or a 900-031. If you look on page 10 of this manual, it will show where the model # is located. Then you can look on the pages for that particular model.
#6 DZG OFFLINE
DZG
  • 609 Thanks
  • 526 posts
Posted November 22, 2016 - 10:39 AM
Thank you i apperciate that. Ill do some browsing now.
I think i must not of seen the manual section cause im on mobile, but as soon as i get home ill make a positive ID.
Thanks again
#7 DZG OFFLINE
DZG
  • 609 Thanks
  • 526 posts
Posted November 22, 2016 - 04:34 PM
Ok, i found the numbers, but im not sure which one is which, i couldnt find anything close in the manual besides a 2300 series which is a 4 speed.
Numbers are as follows.
8187.
3139 2316
#8 DZG OFFLINE
DZG
  • 609 Thanks
  • 526 posts
Posted November 22, 2016 - 05:27 PM
poo, now i got another issue...
Went to pull the brake caliper off, and the damn bolts snapped flush with the case...
Can these be easy outed or drilled/tapped without cracking anything? Or am i screwed?
