Here is my snow removal tractor made for beating on. I bought it for a spare motor for my suburbans. For 75 bucks. I have the newer style plows for my suburbans that mount with one pin . Which in my opinion mount so much nicer than the older style. I got tired of beating on my good restored tractors in the snow. This newer gt16 already had a mount which was a bit skinnier. I only had to drill one hole in t mount to get my suburban plow on it. And one in the lift link under the tractor to get it to pick up high enough. And I drilled two holes in the floor boards to mount the lift arm. I had a set of chains for 23x10.50 tires . The gt 16 had skinny tires the chains wouldn't fit. So I put an extra set of wider tires and wheels on it and some spare wheel weights I had. It all fit really good after the small modified mount I did. I'm really excited to try it out because I do not have to care about this tractor so much. Because it is not that great. So I can hog on it a bit. I included a pic of my gt18 mount so you can see how it was made. And also my garden plow 3pt sleeve hitch adapter some of you guys wanted to see. I apologize about the pics. This new Samsung phone always posts sideways on here no matter what way I hold it. My only problem is picking the toy I want to use . I have a custom 10 with snowblower I can use. This blue 16. And a big toro power max for snow.
Edited by KennyP, November 20, 2016 - 10:33 AM.
Adjust Phone Gravity
