Wheel weights
8 replies to this topic
#1 molineman OFFLINE
molineman
  • 5 Thanks
  • 9 posts
Posted November 19, 2016 - 07:31 AM
Are Power King wheel weights hard to find? What kind of weights are people using? Will IH cub front and rear weights fit? What paint color matches the Power King orange the best?
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,353 Thanks
  • 4,961 posts
Posted November 19, 2016 - 07:38 AM
If you have the 24 inch rear wheels the I-H and Farmall Cub weights are the same.
If you have 16 inch rear wheels the rear weights are probably different.
JP Tractor Salvage in Missouri has rear weights for $65/pair.  Shipping might be $$$$
J.I. Case "Flambeau Red" is the best color match.
Edited by Gtractor, November 19, 2016 - 07:44 AM.
  • molineman said thank you
#3 molineman OFFLINE
molineman
  • 5 Thanks
  • 9 posts
Posted November 19, 2016 - 07:40 AM
Will the front cub weights work?
#4 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,353 Thanks
  • 4,961 posts
Posted November 19, 2016 - 07:45 AM
Yes
#5 molineman OFFLINE
molineman
  • 5 Thanks
  • 9 posts
Posted November 19, 2016 - 08:01 AM
Kris,
        What are the weights I need to purchase from JP? What are they for or from? I have the 16" wheels. I thought you meant they had weights for the 16"
Edited by molineman, November 19, 2016 - 08:05 AM.
#6 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,353 Thanks
  • 4,961 posts
Posted November 19, 2016 - 08:03 AM
If your Power King has 24 inch rear wheels you need Cub rear weights.
Very bottom of this page.
http://www.jptractor...ventorySubId=11
#7 MNGB OFFLINE
MNGB
  • 2,139 Thanks
  • 1,417 posts
Posted November 19, 2016 - 08:50 AM
Hi molineman, there is a set of 16" PK wheel wts on e bay, also the Case 400 series GT wheel wts will fit they are not the same as the PK ones but are just as heavy has a set on one on my PK 1614's are your rear tires ballasted if not windshield washer fluid works good you can get abot 8 / 9 gallons in each tire. Also some front wheel wts from farm tractors with 16" wheels will work.
How about some pictures of your PK
Edited by MNGB, November 19, 2016 - 08:51 AM.
#8 MiCarl ONLINE
MiCarl
  • 2,057 Thanks
  • 1,058 posts
Posted November 19, 2016 - 07:09 PM
If your PK has 16" wheels I believe it's an implement wheel like my Speedex uses.
I got a pair of these https://www.amazon.c...t/dp/B01277BQCY 40lb weights for my Speedex.  The only problem with them is the notches are in the wrong place for the valve stem on my wheels so I had to mount them on the back.  The center hole is big enough to clear my hubs.
#9 molineman OFFLINE
molineman
  • 5 Thanks
  • 9 posts
Posted November 30, 2016 - 06:47 AM
I think I might have found some rear weights but could someone give me the OD and ID dimensions for the weights that go on 16" wheels ? Here's a picture of my PK I recently bought.20160924_144957.jpg
