Jd 316 help!!!!
2 replies to this topic
#1 Firepuppy OFFLINE
Firepuppy
  • 5 Thanks
  • 3 posts
Posted May 31, 2011 - 11:53 AM
I have a John Deere 316 and when i engage the mower deck the governor kicks in and when i start to mow the mower starts to dog down until it almost stalls until i put it in nuetral and it will regain its power
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 31, 2011 - 03:52 PM
Welcome to MTF. First thing would be to check the deck to make sure it is running freely. If there is a stuck bearing or something bent it could be loading down the engine. If the deck is OK then you need to look at the engine. I'm sure others will offer you more advice.
:welcome:
  • 14,889 Thanks
  • 15,514 posts
Posted May 31, 2011 - 04:17 PM
Firepuppy,
I want to welcome you to GTtalk, I'm sure that JDBrian meant the same thing. I need a little more info, does the tractor bog down with mower on and moving, or just when mower is on and sitting still?
