Shop Heater Upgrade
26 replies to this topic
#1 KennyP ONLINE
  • 35,135 Thanks
  • 44,144 posts
Posted November 15, 2016 - 01:45 PM
I have a 35 gallon drum made into a wood burner for the shop. Needed a way to move the heat around. I had an old range hood we took out of a remodel. The fan (2-speed) still worked good, so I made some legs for it and set it over the wood burner. The ell on the top is an 8" and just sitting there. I can move it about to direct air flow.
  • olcowhand, DH1, ducky and 18 others have said thanks
#2 Traill95 ONLINE
Traill95
    Traill95
  • 1,809 Thanks
  • 999 posts
Posted November 15, 2016 - 01:59 PM
Neat,  Redneck Engineering at it's best.. :thumbs:  :thumbs:
  • KennyP, MFDAC, boyscout862 and 1 other said thanks
#3 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 839 Thanks
  • 710 posts
Posted November 15, 2016 - 02:31 PM
Nice! And of the light still works, you can see of you feel like cooking out in the garage.
  • Alc, KennyP, MFDAC and 2 others have said thanks
#4 HDWildBill OFFLINE
  • 8,972 Thanks
Posted November 15, 2016 - 02:41 PM
The PO of our last house owned an HVAC business.  He did something similar to the wood burning stove in the Den.  He made a vented hood over the stove with the exhaust pipe going through the vent.  The vent went up to the attic to an air handler then ducted through out the rest of the house.  It did a fair job keeping the rest of the house warm but you could always notice a difference between the den and the rest of the house.  Pretty cool idea Kenny.  You should stay toasty warm this winter.
#5 propane1 OFFLINE
propane1
  • 7,988 Thanks
  • 3,862 posts
Posted November 15, 2016 - 03:13 PM
Nice idea. But was wondering, is the heat going to bother the plastic fan blade, motor and switches.
Noel
#6 KennyP ONLINE
  • 35,135 Thanks
  • 44,144 posts
Posted November 15, 2016 - 03:33 PM
Noel
First, the blade is aluminum. Second, this is a range hood, made to direct heat away from the cooking area. So I think it will do well at it's new location.
  • boyscout862 and propane1 have said thanks
#7 Billy M OFFLINE
Billy M
  • 596 Thanks
  • 517 posts
Posted November 15, 2016 - 04:09 PM
I know a guy that has an over/under 2x 55 gallon barrel setup.  He put it a couple feet out from the exterior wall.  He runs a cheap box fan behind the barrels to push the air past the barrels/away from the wall.  It works great to move the heat.  That setup would probably move more air than the range hood, although I do like the repurposing.  :D
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,163 Thanks
  • 9,631 posts
Posted November 15, 2016 - 04:15 PM
Third, does it get cold enough there to warrant a fire?
  • ducky, Alc, KennyP and 1 other said thanks
#9 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted November 15, 2016 - 04:24 PM
That is using the old noggin there Kenny.
#10 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted November 15, 2016 - 04:28 PM
 Good job, Kenny!! Us folks in the cold country mount a ceiling fan to push the heat from a wood stove back down to floor level.
                                              Mike
#11 KennyP ONLINE
  • 35,135 Thanks
  • 44,144 posts
Posted November 15, 2016 - 04:30 PM
In the mornings, Cat! Why do you think I only have a 35 gallon drum for the wood burner?
#12 TomLGT195 OFFLINE
TomLGT195
  • 3,473 Thanks
  • 2,670 posts
Posted November 15, 2016 - 05:42 PM
I like the ability to change the direction of heat flow, nice!
#13 KennyP ONLINE
  • 35,135 Thanks
  • 44,144 posts
Posted November 15, 2016 - 06:00 PM
That took some engineering to figure that out!
  • TomLGT195 said thank you
#14 Bmerf OFFLINE
Bmerf
  • 1,794 Thanks
  • 1,466 posts
Posted November 15, 2016 - 06:50 PM
Nothing beats a wood stove for taking the chill off. This reminds me, I need to split some wood and bring it inside.
#15 chieffan ONLINE
  • 8,811 Thanks
  • 6,047 posts
Posted November 15, 2016 - 09:03 PM
Have had the corn stove going for a while now.  Have some old corn from last year to burn up.  New corn this year is cheap heat at $3/bu.  A bu. of corn will put out a lot of heat.  The colder the weather gets the less wood pellets I use as I turn the stove up a notch or two.
