Stack on the HT20
23 replies to this topic
#1 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted November 15, 2016 - 12:59 PM
Down the road I plan on adding my loader to this machine, and thought since I had a little time to burn today, I'd play around a little.
I plan on adding a new elbow, and maybe a rain cap, but definitely will be adding some sort of baffle in the process. Notice the tin can patch with a hose clamp.
Once I have everything where I want it, I'll add a crutch, but figured this is ok for test fitting.
  • WrenchinOnIt, Traill95, boyscout862 and 1 other said thanks
#2 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted November 15, 2016 - 06:06 PM
I need a manifold for mine to change my two stacks into a single stack.. Plus I just have two spark arresters now and she is load.
  • stiemmy and SC Farmer have said thanks
#3 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted November 15, 2016 - 11:29 PM
Bet it sounds good like that in true duals!
  • AA Hayes said thank you
#4 SC Farmer OFFLINE
SC Farmer
  • 247 Thanks
  • 156 posts
Posted November 16, 2016 - 01:56 PM
I had a broken manifold on my 1886 that one of our good sponsors helped with replacing.  I'm sure someone can help you find one.
Edited by SC Farmer, November 16, 2016 - 01:56 PM.
#5 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted November 16, 2016 - 02:38 PM
To eliminate the stacks, you could mount each muffler to the stubs that are screwed into the block. Basically unscrew each 90* that you have on there now and attach the mufflers directly to the stubs. Each muffler would then be directed out the sides and shouldn't have clearance issues with the loader either.
Edited by Austen, November 16, 2016 - 02:40 PM.
#6 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted November 16, 2016 - 10:15 PM
It does sound pretty great, but a bit louder than I like
#7 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted November 16, 2016 - 10:16 PM
I quite like the stacks, I would like to add a better style muffle, such as a small Ford tractor muffler, I think it is the 9n or something like than.
Any suggestions?
#8 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted November 16, 2016 - 10:17 PM
The cost is what holds me back.
  • SC Farmer said thank you
#9 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted November 16, 2016 - 11:49 PM
There really isnt anything wrong with the manifold, it's the 1 piece log style. The elbow after the manifold is junk. Since the manifold is good, I'll use that, and just replace the elbow up. I'm going to Fleet Farm this weekend to take a look see. I may go with a different muffler all together?
I'm only running a stack to keep the hot gasses off the hydro lines on the front of the loader. If it weren't for that, I'd probably leave it well enough alone.:)
#10 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 24, 2016 - 03:47 PM
Austen he definitely has something different coming out of the block to accommodate the pipes and twin stacks you can't come straight up out of the block he won't clear the hood, the pics in this post show the factory exhaust flange , you have to fab up a flange to attach to the exhaust ports on the jugs then go horizontal before getting vertical , also here is a pic of a factory Kohler exhaust manifold. Just an FYI buddy I know your '86 has a different set up :)
http://gardentractor...st-iron-repair/
I quite like the stacks, I would like to add a better style muffle, such as a small Ford tractor muffler, I think it is the 9n or something like than. Any suggestions?
IMO you'd have a lot of weight hanging off the bolts into the exhaust ports on the jugs,the relatively small material of the cast iron around the exhaust port that is drilled and tapped for the manifold bolts won't like the additional stress,I'm surprised you're not seeing some metal fatigue with your present set up based upon vibration. Again IMO you'll need some fabbed up bracing.
Just an FYI if it's your loader off your 1455 vertical is your only choice for the muffler on the LF Bolens with the Kohler twins unless you want to re-engineer the set up . I only know of the Johnson 25 having enough clearance to have the muffler remain horizontal.
Edited by WrenchinOnIt, November 24, 2016 - 04:06 PM.
  • blackjackjakexxix, Austen and stiemmy have said thanks
#11 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted November 25, 2016 - 12:25 PM
Yep, vertical was what I am planning on doing. I never went yet to look at mufflers as my work schedule had changed, and now with the snow who knows if it will get done this year. I have seen some really thin mufflers that I think would work vertically, but I rather not go that route anyway. ;)
#12 KennyP ONLINE
  • 53168 Thanks
  • 53308 posts
Posted November 25, 2016 - 05:39 PM
This is the muffler I used on Alice. Sounds real good on the Kohler M18!
And here's the 'crutch' for it.
  • WrenchinOnIt, stiemmy and 29 Chev have said thanks
#13 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted November 25, 2016 - 07:45 PM
I only see the crutch picture!??
Looks good though.
Edited by stiemmy, November 25, 2016 - 07:46 PM.
#14 KennyP ONLINE
  • 53168 Thanks
  • 53308 posts
Posted November 26, 2016 - 08:21 AM
LOL! Forgot to put the muffler link in.
  • WrenchinOnIt and stiemmy have said thanks
#15 Rock farmer ONLINE
Rock farmer
  • 1537 Thanks
  • 1434 posts
Posted November 27, 2016 - 02:51 PM
This is what I have on mine;
I have an industrial engine in there.
It came with those mufflers. And separate manifolds.
I added some pipes to make them fit.
Joe
  • KennyP, WrenchinOnIt and stiemmy have said thanks
