S twin 16
8 replies to this topic
#1 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted November 13, 2016 - 10:18 PM
Was given this to me was told that line we all heard RAN When parked.4 years ago came with deck and nice set of 4 ag tires on the back fronts are shot and lots of rust!had a burnt fuse replaced it got it to turn over. But saw a little smoke from wire from fuse to coil were the 2 wires becomes 1 too the coil looks like they have some kind of resisters?? Is the right But one got toasted. So went. Wire to wire but keep blowing the fuse. But before that I did some good spark and now the wards won't turn off with the key I was hoping to put the scoop on the gilson wards came with front blade tiller but no drive shaft
Edited by Casinojim, November 14, 2016 - 07:48 PM.
#2 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted November 13, 2016 - 11:44 PM
Diode that's what it is. 28 volts 3 amps is this right any know the parts #IMAG0198(1).jpg IMAG0201.jpg IMAG0204.jpg IMAG0202.jpg IMAG0199(2).jpg model 401417_0128_01_78042112 and 53044 45480 best I can make out 😁
Edited by Casinojim, November 14, 2016 - 11:21 PM.
#3 boyscout862 OFFLINE
  • 12,187 Thanks
  • 8,898 posts
Posted November 14, 2016 - 08:54 AM
Try downloading the manual from our Manuals Section. Some clear pics will help us to evaluate the problem. Offhand, I would suspect a shorting wire, possibly caused by mouse chewing. They do it to me alot. Good Luck, Rick
  • Casinojim said thank you
#4 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted November 19, 2016 - 11:01 AM
Thanks for the info got a new diode tues got a chance to get it in got some good spark put new fuel filter on and gas had it running going after some oil and plugs today then the brakes
#5 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted November 19, 2016 - 11:57 PM
Figure it out on the wards not turning off. wire on starter switch was just hanging on. "Good to go ! now back to the gilson. New plugs oil runs good got it all Gerry ridged just to see if it would run,,,,,, its a. Runner
#6 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted November 25, 2016 - 09:21 PM
I just wanted to say thank you again. I did down load some Manuel. I thought I would get some more info and help?? guess its to New the s twin. Seems u all like 60s and 70s more thanks again will try another site ps saw this site on classical tractor feaver. To see a friend Steve Johnson with his collection. Jim
#7 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted December 04, 2016 - 10:59 AM
[quote name="Casinojim" post="729529" timestamp="1480126890"]I just wanted to say thank you again. I did down load some Manuel.
#8 Sprint 6 ONLINE
Sprint 6
  • 226 Thanks
  • 288 posts
Posted December 04, 2016 - 09:30 PM
Both of your tractors are from the '70s.  Wards started with that body in about '76.  The Gilson is basically the same tractor with a different hood and twin cylinder engine, I would guess about '78.  I am guessing on the '78 because Wards models started using the twin engine about that time.
  • KennyP and Casinojim have said thanks
#9 Casinojim OFFLINE
Casinojim
  • 115 Thanks
  • 152 posts
Posted December 04, 2016 - 11:58 PM
Great!! thanks just wanted be b sure . got this Saturday for 50 bucks. Was to be a parts tractor but runs forward reverse stops. Got 120 psi in both cylinders new battery but it's not charging it think the hood might be wrong got one 1 23 10.5 12 ag tire and a 23 8.5 12 which is new. How hard is it to get the rear discharge pice that bolts to the back of the tractor lots of grass on the transmission
