Wheel spacer / Bolt pattern conversion
8 replies to this topic
#1 mjes92 OFFLINE
mjes92
  • 39 Thanks
  • 36 posts
Posted November 12, 2016 - 12:37 PM
I have a H1704 Bolens/Iseki with rear turf tires and would like to change over to the spec'ed 8-16 Ag tires on standard implement rims (Case/Ingersoll 448 rims).  Does anyone have a the bolt hole pattern dimensions of the ISEKI and Case rims.  Are conversion wheel spacers available?
Any help is appreciated.
#2 mjes92 OFFLINE
mjes92
  • 39 Thanks
  • 36 posts
Posted November 15, 2016 - 10:14 PM
Anyone out there with advice?
#3 ducky OFFLINE
  • 2375 Thanks
  • 4342 posts
Posted November 15, 2016 - 10:35 PM
Your 6 bolt rims are 6" x 6 bolt.  If the Bolens is 5 bolt they are 4.5" x 5 bolt.
I made a set of adapters just like that.
Edited by ducky, November 16, 2016 - 12:23 AM.
#4 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted November 16, 2016 - 08:14 AM
 Does anyone have a the bolt hole pattern dimensions of the ISEKI and Case rims?
You do.
This answer may sound rude, but it is not intended that way.
Just measure the bolt pattern in the wheels that you have.
  • 29 Chev said thank you
#5 nyrobbie77 OFFLINE
nyrobbie77
  • 106 Thanks
  • 83 posts
Posted November 16, 2016 - 10:05 AM
Are you also going to change the front tires?  Or just planning on not using 4x4?
#6 ducky OFFLINE
  • 2375 Thanks
  • 4342 posts
Posted November 16, 2016 - 11:34 AM
Bump
#7 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 6045 Thanks
  • 2248 posts
Posted November 19, 2016 - 09:38 AM
You can buy 5 lug to 6 lug adapters on ebay and auto parts stores
#8 DL-North OFFLINE
DL-North
  • 149 Thanks
  • 174 posts
Posted November 21, 2016 - 11:42 PM
I got these numbers off the web someplace,
I haven't confirmed these numbers so use with caution.
Bolens G154 (Iseki TX2140F).
Where d=bolt hole diameter, D=large hub opening diameter, I=diameter of circle bolt holes fall on.
Front D=70mm. I=100mm d=13mm. 4 bolt
Rear D=90mm I=120mm d=13mm. 6 bolt
Dan
BTW, what are your plans for the take-offs? I might be interested.
Edited by DL-North, November 21, 2016 - 11:44 PM.
#9 mjes92 OFFLINE
mjes92
  • 39 Thanks
  • 36 posts
Posted November 25, 2016 - 10:36 PM
Thanks for the spec's.
After 20+ years of machine design and working with machinist I appreciate having the spec dimensions.
